HELP! Weird drivetrain noise....
DBordersX
105
Apr 13, 2007
Redding, California
Ok guys, I've got a weird noise and a couple other things that may or may not be related.
Here we go:
1. When idling, I hear a very faint whine/squeal (similar to squeaky belt). When I push the clutch IN this noise disappears. (Pedal out = Noise, Pedal in = Silence)
2. When driving I randomly hear a faint chirp sound (like very short squeal). When this sound happens the car slows slightly as if I had tapped the brakes. The sound and the slowing are both very faint but gradually becoming less faint.
3. When in neutral, if I try to hold the RPM's ner 2K, there will be a click and the engine will jump to around 3K... without me moving my foot at all.
Now, I have searched (mostly on 1 and 2) and I was thinking that the throw out bearing could be bad. Now I've still been looking and I read somewhere that when the TOB goes bad then it will make noise when the clutch is DEPRESSED. Mine makes noise when the clutch is RELEASED.
I really want to get through my drivability issues so I can start playing with my new car! :cry:
Thanks in advance guys.
The noise could still be the throw out bearing, my truck does the same thing, I've just been ignoring it(which I don't recomend anyone else do) until i have to replace the clutch. It's been doeing it for a good 3 years now and has not gotten any worse(or better),but I don't drive far and it sits all winter so it don't get salt on it.(makes alot of sence park the 4wd in the winter, I know)
does it also do the weird slow/chirp thing when you're moving? (mine only seems to happen above about 2K rpm)
Ok so I finally got around to getting the tranny out last night. How can I tell if the TOB is what was causing my problems? It seems to spin fine, actually a little easier than the new OEM one I got from RRE? It's also a tad bit bigger it looks like. I'm assuming this is the one that came with the ACT 2600 clutch that's in there but I didn't do it so I don't know for sure.
There was no visible damage to the pressure plate or any other clutch components. The fluids from the tranny and the T-case were both clear and metal-free.
Anyway, what I really want to know is: is there any way to tell if the TOB was what was causing me these problems just from looking at it? Is there anything else I should check while I have the tranny on the ground?
