Help solve my knock issue
iron bird
166
Nov 7, 2008
Beaver Falls, Pennsylvania
log attached i need help solving horrible knock.
What mods, only gm maf? What boost? Need a little more info. With what I can say it looks like too much timing at high rpms since you probably have the boost turned up or a lean condition due too a bad tune with the gm maf.
stock maf, 15 psi, fuel pump rewire, 3" turbo back, im replacing my plugs too, there probly bad causing a bit to when my ecu fried my car ran super rich.
well, I wont' trust the stock o2 reading any further than to say that you do lean out from your richest point around 5k (where the knock starts) and continue to lean towards redline as knock picks up.
also, airflow is erratic and your probably just pushing a ton of hot air into the engine (the reading in the log is at the MAF right?)
So all in all, I see you leaning out right when the knock starts (injector pulse dips from the peak21ms and falls steadily),while running out of flow from the turbo or engines breathing setup making the air super hot on top of the lean'ness and you're asking for knock... Do you have any wideband readings? i'd say you're in need of some upgrades in the cam, turbo and fuel departments
I know you're only asking to get rid of the knock on the setup you have, but it may be the setup at the levels you're trying to run that's causing your knock... AT the least it needs a tune put on it that can keep the AFR's right after 5100RPM
its fixed guys sorry i didnt post back new spark plugs and every thing was fine
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
