*HELP* Push Button Starter w/ relay and then some
GS-T SL33P3R
Nov 8, 2011
Millington, Tennessee
Hey all,
I recently decided to put a push button start in my 96 eclipse and having no clue about electical I may have bit off more than I can chew. However, I am determied to do it all with out going to a mechanic. I have attached some pictures so that you all could get a good look at the product. The company I bought it from emailed me a PDF with a diagram but not a very good one. I am trying to eliminate having to turn the key as well. I has the switch to assist in that. If any one has any insight to this probem I would be most appreciative. :D
Your question?
My question(s) how do i properly wire it all withthe relay to where i just flip the switch and all my accessories, starter, fuel pump kick on and then i can just press the button and the car starts up. Sorry i forgot to make that clear in the initial post.
*I got the push start to work but the L.E.D doesnt light up and I still have to turn the key.
Thanks
Your going to have to use a switch to "replace" the ignition switch.
Otherwise, all ignition hots will be hot all the time.
Your switch needs to mimic the key being in the "run" position when flipped on.
