Help on 1gin2g swap
Mattmeek_GST
32
Jan 25, 2004
Shreveport, Louisiana
okay, I know about the magnus and rre site. Its not enough info. First can the 2g timing belt cover be modified to fit? What about the lines to the turbo(t25)oil & water will the 2gs work? Can I use my 2g coil pack? may be a dumb question,but is the water pump inlet pipe the lower radiator hose? Do I still swap spark plugs? I have a 95 gst with head/block 6 bolt. where do you sodern,however its spelled, the cam wires at? I have the wiring diagram. Is there anymore stuff that Magnus or rre doesnt cover? I got dsm link already.I know about RM.
alot of it depends on if your doing a full 1g motor or just the block with 2g head?
full 1g motor = 1g water pipe so ya need 1g water lines.(im sure ya can rig 2gs up if ya really wanted to )
ya can use either coil pack.
ya need a 1g t-belt cover.
95's still swap either the plug wires or swap the triggers on the triangle plug going to the coil pack. ya also need to swap the injector wires.
ya solder were ever you tap the wires :p
