1Gin2G T-belt prob
TheBoosted96GST
107
Jun 16, 2002
Avondale, Arizona
well i have a 96 GST with a complete 6-bolt block and head..the problem i'm having is the t-belt slides off the idler pulley not completly off but enough it started rubbing on the t-belt cover..so I ordered a new motor mount bracket and idler pulley it comes from mitsu. as an assembly i thought that'd be my problem..so I put it on and put the new t-belt on it still seems to slide off only a tiny bit this time, i'm thinkin this still isn't normal..i gotta pull the belt off again cause its one tooth off on the cam gears,some help please this car has been a PITA, i'm pretty positive that the mount is flush to the block, anything else it could be? thanx in advance
