HELP! Cooling fan not working.
mickey
289
Aug 7, 2011
New Haven, Connecticut
i been doing this for a month and still cant find out how to fix it. i read other thread but i dont understand it. someone need to explain to me very easy for finding out how to fix my cooling fan. all i know is check a wire if is good but it good, check relay if it good but look good to me and check fan switch (i dont even know where is that) they told me around the head of the engine but i still dont get it. other people say get wire straight to battery to see fan system work...well i dont what to do. Can you tell me how to check or what to find? please explain to me easy.
Make a jumper. (aka piece of wire in a U-shape). That way you can check the fuse. If the jumper turns the fan on then your fuse is bad. If it doesn't the fan motor is probably bad.
if you can't find something, pick up an manual and read it will tell you where its at, if that fails google and youtube are you friends.
