Cooling fan not working?!!
mickey
289
Aug 7, 2011
New Haven, Connecticut
my cooling fan not working at all. but there are weird part too, when i stop at the red light, the temp warming up to almost hot but when i drive, it low it down lil bit....i dont know why my cooling fan not working. is there you can tell me what to do or where to check to solve it?:cry:
The reason why your coolant temp gauge goes up when at a light is because no air is going through your radiator hence nothing is cooling down your coolant. When you start going air flows through the radiator and cools down your coolant.
First things first check the connectors, wires, and fuses to make sure they’re in good condition
Got a raidator fan thermoswitch on that car? i would check that first. unplug it, bridge the connection, if your fan turns on then, theres your problem.
i dont really know where thermos switch located at. can u explain where it located at? i got 420a :confused:
