HELP! Car misfiring on all 4 cylinders when cold
italicizesponge
May 20, 2006
detroit, Michigan
when i first start up my car and try to drive down the street, my car misfires on all 4 cylinders making it impossible to go even over 20mph. but as soon my car warms up, its fine except a little throttle hesistation. im not sure what this means but i have a autometer air/fuel ratio gauge gauge hooked up and it bounces from stoich to rich with no throttle, goes wayy lean when using throttle, and wayy rich when letting off.(backwards) my maf is fine. my spark sparks & wires are fine. could it be my o2 sensor? i just ordered an ignition coil because it had a tiny little crack in it, could that little crack make my misfire when cold, but be fine when its warm? all help is appreciated
oh yea and i forgot to add at speeds from like 70-85mph when i let off the gas and try to push back on it it stumbles for a few seconds and catches and i have throttle again
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
