firing on all cylinders?
1Gina2G
810
May 6, 2011
Beaufort, South Carolina
how does one tell if there's misfires, or if all cylinders are firing? How would the engine sound while running?
there would be a noticeable difference in sound at idle. What I have always done is start at the number 1 plug and while car is running pull it up off the spark plug. If that cylinder is missing and not firing then there will be no change in sound. If you pull it off and the engine idle sounds different then that cylinder is firing. Do this for all 4 cylinders. If you do all four and each one changes the sound then they are all firing
Thanks alot for the reply. Always reading about people who find that one or more of their cylinders aren't firing, never figured out how they could tell.
I was also wondering, since I have a inductive timing light, would I be able to use the spark plug sensor to see if all the wires light up? That should work right?
IMO misfires on 4 bangers are very easy to identify. you will hear a short hesitation or shudder. as to what cylinder it is coming from, remove one plug wire from the plug at a time. listen to the rmp at idle of the car. it the rmp drops when you remove that plug wire that cylinder is firing. if the rmp doesn't change once a wire is removed that is a "dead" cylinder. good luck
You can tell if your care is misfiring, if you gas it, and you feel a loss of power when increasing pressure on the pedal. Also u will notice the change in feel of the car as it happens.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
