ECMlink Help!! 950cc injector e85 with t04b turbo
1970eclipse
Dec 15, 2011
sunset, South Carolina
Are 950cc injectors to small to run e85 with a bullseye t04b vtrim turbo?
MODS:272 cams
walbro 255
balanced shafts removed
6bolt block 2g head
jmf sheetmetal intake
vrsf fmic
dsmlink v3
wideband, oil ,boost gauges, Autometer
3in exhaust
950 fic injectors on 93 pump gas.
forge recirculating bov
t04b turbo with internal waistgate
ported evo exhaust manifold.
ARP headstuds.
aeromotive afpr
95 talon RED ROCKET!!!!
Depends what t04b you have. A single Walbro maxes out at close to the same flow as 950's anyway. If you want to upgrade get a better pump, or another of the same pump, and some larger injectors.
this one is 48lb/min. DOES anyone have the fuel requirments for these turbos running e85????? Do i need to up the injectors or will the 950cc handle it.......has anybody had success with this setup???
They should be enough. Most people have trouble making more than low to mid 300's with the v-trim.
A set of maxed out 950's actually supports around 50lbs/min depending on the rest of the fuel system.
390cc @ 100% IDC will support 21.80 lbs/min. Global Correction: +50.00%
390cc @ 80% IDC will support 17.44 lbs/min
450cc @ 100% IDC will support 25.15 lbs/min. Global Correction: +30.00%
450cc @ 80% IDC will support 20.12 lbs/min
550cc @ 100% IDC will support 30.74 lbs/min. Global Correction: +6.36%
550cc @ 80% IDC will support 24.59 lbs/min
580cc @ 100% IDC will support 32.42 lbs/min. Global Correction: +0.86%
580cc @ 80% IDC will support 25.94 lbs/min
650cc @ 100% IDC will support 36.33 lbs/min. Global Correction: -10.00%
650cc @ 80% IDC will support 29.07 lbs/min
660cc @ 100% IDC will support 36.89 lbs/min. Global Correction: -11.36%
660cc @ 80% IDC will support 29.51 lbs/min
680cc @ 100% IDC will support 38.01 lbs/min. Global Correction: -13.97%
680cc @ 80% IDC will support 30.41 lbs/min
720cc @ 100% IDC will support 40.24 lbs/min. Global Correction: -18.75%
720cc @ 80% IDC will support 32.20 lbs/min
750cc @ 100% IDC will support 41.92 lbs/min. Global Correction: -22.00%
750cc @ 80% IDC will support 33.54 lbs/min
780cc @ 100% IDC will support 43.60 lbs/min. Global Correction: -25.00%
780cc @ 80% IDC will support 34.88 lbs/min
850cc @ 100% IDC will support 47.51 lbs/min. Global Correction: -31.18%
850cc @ 80% IDC will support 38.01 lbs/min
880cc @ 100% IDC will support 49.19 lbs/min. Global Correction: -33.52%
880cc @ 80% IDC will support 39.35 lbs/min
950cc @ 100% IDC will support 53.10 lbs/min. Global Correction: -38..42%
950cc @ 80% IDC will support 42.48 lbs/min
1000cc @ 100% IDC will support 55.89 lbs/min. Global Correction: -41.50%
1000cc @ 80% IDC will support 44.72 lbs/min
1150cc @ 100% IDC will support 64.28 lbs/min. Global Correction: -49.13%
1150cc @ 80% IDC will support 51.42 lbs/min
1200cc @ 100% IDC will support 67.07 lbs/min. Global Correction: -51.25%
1200cc @ 80% IDC will support 53.66 lbs/min
1600cc @ 100% IDC will support 89.43 lbs/min. Global Correction: -63.44%
1600cc @ 80% IDC will support 71.55 lbs/min
1850cc @ 100% IDC will support 103.41 lbs/min. Global Correction: -68.38%
1850cc @ 80% IDC will support 82.72 lbs/min"
Taken from a set of posts by darkhorse
Thank you. Someone had to clear the bullshit outta the air. Coulda got some crazy speculation.
1000cc ptes here, 52lbs min and thats nearing the limit/right at the limit
You can run your "T04B"?? with 950s and e85
