We're on Boost
- 3,150
- 1,560
- Aug 25, 2007
Seattle area,
Washington
Ahh ok, IdleSwPin. Looks like IdleSwPin worked a few times and other times not. So he could try to get that working better. But the simulated idle switch like he's got turned on in log 3 seems to be working ok. I think it looks like his actual throttle position is hanging up a little at ThrotPos 1% and then it vibrates down to 0% after some time.It's IdleSwPin as I understand it that is the raw indication of the IPS input. If it's switching when it should you don't need to enable simulation.
Yeah.alright so i got another log here for you, non of those things seemed to help too much, the fuel pressure i think did help it idle on its own a bit better but not by much here is the log
I see the engine quit at 171 sec, then a restart at 181 sec. Another restart at 234 sec. It takes about 30 seconds for the wideband to start working again after the restarts, so for most of the time after 171 sec there is no wideband, no simulated narrow band, and therefore no closed loop.
But before 171 sec there is about 50 seconds of closed loop, and for most of that the Combined and Short Term Fuel Trims are still mostly way high, 16.8.
One thing to do, look at all 4 spark plugs. See if one of them looks a lot different than the other 3. You might have one cylinder running with a cloggy injector. The running till now has been so light though, the plugs might not show much of anything.
What are you using for a fuel filter, and have you checked or changed it lately?
When I right click on your log window and pick "MAFComp Adjust (Combined FT)" from the right click window, and then it shows me your MAF Comp tab with suggested changes, it shows suggested changes of about plus 14%. But it only has suggestions for up to 100 MAF hz. Because that's about all we have so far with this very light running.
I think the next thing to try in ECMlink is to change your Global Fuel number.
If you run the calculator for 850cc injectors, still telling it 37psi pressure, you'd be adding about another 11% to your fuel from where you are now.
In other words, like this:
So you'd change your Global Fuel from -53 to -47 about.
It's just a shot at it, but easy to do and easy to revert if you find something more fundamentally wrong.
