headlight issue
1994
33
Nov 24, 2012
St clair, Pennsylvania
Hey I have a 94 talon. My issue is that when my cars off the low beams will work if I start the car they go out. If I try and turn them on while the cars running they just flash once and stay off also my highness don't worm at all. Even the indicator on the dash don't light up to the high beams.
every other light works but my headlights
any ideas?
Definitely check the relays for the head lights in your engine bay fuse box. Might be a blown relay or fuse acting up. Also check the headlights wiring harness could be a cut or pinched wire causing a short in the wiring somewhere or a bad ground .
As stated, check the relay... find another that isnt necesary for anything else workin properly, like say the horn relay, and swap them. if all is good, you know you need a relay. At the same time check the fuses for all the lights, not just low beams. Then be sure there are no frays in the wiring harness or a short anywhere.
My buddy's S2K was having a problem with his high beams kicking all of his lights off while driving... come to find out, his tires chewed through the fender liner and wire insulation and was causing all sorts of trouble.
Hey guys thanks fi r the help it turned out my hids were messing it up so I put regular bulbs back in and finally drove it to work monday night and ended up wrecking it in the snow.
So now I just bought a 92 gsx and the motor swap starts tommrow. Cant wait
