Header bolt missing
dfresh702
40
May 10, 2011
Springs, Colorado
I noticed last night that a header bolt is missing. Is it possible to throw in a bolt and avoid taking everything apart to install a stud?
It's a stud and a nut, not a bolt.
Yes, you can install a replacement without removing anything, as long as there isn't thread damage. Usually when there's a missing stud, it's because the threads are ripped out of the head. In that case, you'd have to pull everything off and helicoil it.
I would use a stainless steel bolt. Plain steel bolts tend to glue themselves on to the aluminum threads after a while, when you try to take them out, the threads get chewed up.
Acehardware got plenty of stainless fasteners.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
