head gasket oem or metal?
sleek98
99
Apr 9, 2005
Kansas City, Missouri
ok so im replacing my head gasket and was wondering if i should get a metal or an oem. i plan on running max of 26 psi, depends on if the 2600 will hold. I have a 6 bolt with arps.
so i have narrowed down my choice to the titan ics gasket with the built in orings or the oem. im wondering if i need to redeck the block for that particular head gasket. also can the stock head gasket take 26 psi? i have dsmlink to tune with and will be getting 950 injectors. so there wont be any knock.
chris
Oem metal is fine for your application. Throw in some ARPS to button down the head and make sure to have a clean block surafce and have the head decked if needed.
Edit I see you have the ARPS already. :)
I agree I have a 4 layer metal head gasket from mitsu and it works fine and now that you already have arp's your set so go metal !!!! :thumb: :dsm: :thumb:
well here is the thing, its got a mitsu 4 layer, and im pretty sure that it is leaking between the layers so thats why i wanted to go with the titan because it has an oring in it.
chris
Wel I have the 4 layer and I have no problems did you torque spec the bolts for the head to connect the block? sound stupid but some people dont know. if so maybe when you were putting it on the gasket got damaged it happen to me once and I had to get another one. Another thing wy did you changed your head gasket maybe your head is warped and if that was already amchined I have some bad news it might even be your block the is warped. Alot of possibilities.
the motor got built so thats why it was replaced in the first place, forged internals, so the block was decked about 10k miles ago. im guessing that he didnt use spray or he got a damaged one not sure, i bought the motor used from someone. it has 10k on it. i think im going to go with the titan
chris
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
