oem organic head gasket
4g63eagle
151
Nov 3, 2009
arozonoo, Africa
im on maperformance.com and im trying to order my top end gaskets and i have some choices on head gaskets no cometic its between a oem organic? head gasket and the oem 4 layer"dont trust" so here is my question what head gasket to buy oem mitsu $52.00 or the oem 4 layer $115 that i heard bad things about using if the head n block are not freshly shaved i dont know what to pick input anyone i was told i cant use the cometic 85.5 86 or 87mm because i have a stock bore
What are your plans? The stock headgasket with ARP headstuds will work great especially if you have not had the head machined or checked for straightness or the block decked. It has been proven to hold well over 400hp. I wouldn't use an MLS gasket without knowing for sure that all your surfaces are perfect and flat. As far as Cometic goes the 85.5mm will work for stock bore. That is just how most places stock and sell them.
thank you im gonna shoot for the stock one then i did not have the block done so the mls is a bad idea if things are not freshly machined i have heard alot of that lately just wanted to be sure....why is it called organic?
oh ok i just wanted to make sure that did not change quality. so at maperforfmance.com i got a cometic top end gasket kit, oem mitsu organic head gasket,ARP head studs i got a new head last night from a trusted source and a freshly sand blasted valve cover so i think im covered thank you again for the help on head gasket choice the organic part was throwing me off a little
The material it is made from.
It is highly unlikely that Mitsu didn't use pesticides and other chemicals when growing these "Organic Head Gaskets".
I think the word you all are looking for is Composite, and I would bet my bottom dollar that every single component of those "Organic Head Gaskets" are made from synthetic materials...
It is called organic for a reason. It is anywhere from 10%-40% inorganic materials such as rubber and other fibers and from 60%-90% organic materials such as graphite.
I guess you didn't get my joke...
I realize there is graphite in the gaskets, but when you construct anything from a lot of different materials, it's called a composite.
All depending on the percentage or organic to inorganic materials used. Over a certain percentage and organic becomes composite.
Does anybody know what max bore an oem head gasket will take? .020 .030 .040?
And I'm speaking for a 2g 7 bolt gasket.
or⋅gan⋅ic  /ɔrˈgænɪk/ Show Spelled Pronunciation [awr-gan-ik] Show IPA
Use organic in a Sentence
See web results for organic
See images of organic
–adjective 1. noting or pertaining to a class of chemical compounds that formerly comprised only those existing in or derived from plants or animals, but that now includes all other compounds of carbon.
2. characteristic of, pertaining to, or derived from living organisms: organic remains found in rocks.
3. of or pertaining to an organ or the organs of an animal, plant, or fungus.
4. of, pertaining to, or affecting living tissue: organic pathology.
5. Psychology. caused by neurochemical, neuroendocrinologic, structural, or other physical impairment or change: organic disorder. Compare functional (def. 5).
6. Philosophy. having an organization similar in its complexity to that of living things.
7. characterized by the systematic arrangement of parts; organized; systematic: elements fitting together into a unified, organic whole.
8. of or pertaining to the basic constitution or structure of a thing; constitutional; structural: The flaws in your writing are too organic to be easily remedied.
9. developing in a manner analogous to the natural growth and evolution characteristic of living organisms; arising as a natural outgrowth.
10. viewing or explaining something as having a growth and development analogous to that of living organisms: an organic theory of history.
11. pertaining to, involving, or grown with fertilizers or pesticides of animal or vegetable origin, as distinguished from manufactured chemicals: organic farming; organic fruits.
12. Law. of or pertaining to the constitutional or essential law or laws of organizing the government of a state.
13. Architecture. noting or pertaining to any work of architecture regarded as analogous to plant or animal forms in having a structure and a plan that fulfill perfectly the functional requirements for the building and that form in themselves an intellectually lucid, integrated whole.
14. Fine Arts. of or pertaining to the shapes or forms in a work of art that are of irregular contour and seem to resemble or suggest forms found in nature.
–noun 15. a substance, as a fertilizer or pesticide, of animal or vegetable origin.
Origin:
1350–1400; ME: pertaining to an organ of the body < L organicus by or employing a mechanical device, instrumental < Gk organikós equiv. to órgan(on) organ + -ikos -ic
Related forms:
or&#8901;gan&#8901;i&#8901;cal&#8901;ness, or&#8901;ga&#8901;nic&#8901;i&#8901;ty &#8194;/&#716;&#596;rg&#601;&#712;n&#618;s&#618;ti/ Show Spelled Pronunciation [awr-guh-nis-i-tee] Show IPA , noun
Synonyms:
8. inherent, fundamental, basic
Antonyms:
1. inorganic.
I do believe 20 over is max. Correct me if I'm wrong. I remeber seeing it on one of the vendors sites.
