2G GST Megan Racing catback exhaust installation issues
snowborder714
Moderator
16,188
466
Oct 15, 2006
Mechanicsburg, Pennsylvania
I'm replacing my old rusted out exhaust with a Megan Racing unit. I noticed that the exhaust hangers are off by 90* and have threaded holes in them. Should I be running bolts through the rubber hangers off the body and into the threaded holes? Or should I be rotating the rubber hangers 90* and utilizing them as stock?
If using the stock rubber hangers rotated, how am I supposed to use the metal hanger at the back of the piece that connects to the downpipe? The hanger is parallel to the exhaust pipe and basically touching it at the end that you'd slip the rubber hanger onto it.
You have to bolt the hangers onto the pipe hangers before install then just slip the other end on the hangers on the car . A little lube helps them slip on easy.
Also the $100 GST downpipes off eBay are an excellent match.
I just bought this exhaust and I’m wondering the same thing. What did you end up doing? How did you connect those hangers cause I’m confused too
I had to take it to a shop with a lift and loosen up all connection points. While we were able to get the muffler section in and mostly bolted up (with a lot of struggling), it was all up in my bumper. We loosened up the other two connection points and removed all of the hanger bolts and it was able to settle into place. Then we tightened up the connection points and bolted the hangers back in and it sat great in the bumper.
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
