Greddy FMIC 24v [merged 1-08] intercooler installation fitment pics instructions
boostineklipz
1,361
Jun 2, 2002
1, Maine
Eclipse/Talon 95-99 GRED 12030000 18R (Rspec)
Eclipse/Talon 95-99 GRED 12030001 280x600x76mm (24 Rspec )
What is the difference between the 18R and the 24R?
One is $815 and the other is $900.
The Greddy IC is set up for the stock location turbo. With that said, there are many kits for a 2g that include a J pipe that points the outlet (cold side) of the turbo down to the stock location. There is still need for a 90 degree elbow at the end of the J pipe to connect to the lower pipe of the Greddy kit. Make sure that whatever J pipe you get has a lip at the end of it and is not just smooth because it will just blow off under higher boost pressure.
Just got the pipe that runs from the top outlet across the fmic. Nothing else. So I have to get everything custom from a muffler shop.
Just needed a visual to get my mind right.
As mentioned RRE sells jpipe and lower ic pipe that will meet at the stock smic location, which should bolt up to greddy small or large fmic kit. I know because it was my old setup ;)
dejontool also sells the necessary pipes. Others as well.
Hey guys i just bought a greddy 24r intercooler kit off some dude for 300 bucks he also threw in the greddy type s bov, and i was wondering if anyone had complete pictures of the whole kit upper and lower piping put together, because im kinda confused about it thanks.
Here you go:
You should have a S pipe with your kit that looks something like in the pic below. The arrow is pointing to the S pipe in the pic. You connect one end to the lower pipe coming from FMIC core and the other end to the turbo. Pretty simple...
