2G Gm Maf questions
So in order to run a gm maf you must have either a maf translator, booo, or dsmlink with their gm maf cable, hurray!!!
You cannot simply put the gm maf in and expect it to work. You need to have a way of tuning.
Also I would not spend $240 dollars on the maperformance gm maf, I don't think there is anything wrong with it but if you go to a local junk yard you can pick one up for less then $100. There is a list of compatible cars on this site somewhere, with a little bit of searching you will find it pretty easy. Hope this helped.
Yea thanks for the help I have a dsm link so I just need to get the cable and I'll try and look at a junk yard
Thank you
It doesn't really matter but if you want to vent your bov to atmosphere then it needs to be in between the bov and the throttle body. Not sure if there is a specific amount of space away from the bov is required but I always go safe and put it right in the middle.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
