GM Maf on 1g Car
91LaSerTurBo3
70
Jan 9, 2008
Saskatoon,
well i was wondering if getting the GM Maf and maf-translator would be a waste of time and money with my setup(3"Turbo-Back Exhaust, k&n Air Filter, k&n CrankCase Breather, Voodoo MBC) i do plan to finish the 1st stage power mods, so thats just there for consideration, also i plan to cure my boost creep, so an power gained from that would also be counted
I love my maf-t setup. It has a very nice injector compensation. For fine tuning I use an safc. Only issue with the maf-t setup is it can cause timing to run high when large injectors are used. I am going to run e85 so timing should still be fine. Dsmlink and the ma-t setup work great together if you can afford it down the line.
alright thanks for that.. but blownturbotsi said "It'll leak, but of course, who cares about performance when you can vent!", but would the maf and maf-t compensate for the lost air? so in theory no performance should be lost? or iam i wrong with this thought
is it alright if i use the stock 1g BOV or would i lose performance in doing this? also ive got some boost creep, and im wondering what i can do to eliminate fuel cut so that i can just let my turbo go nuts LOL, so would adding the maf + translator be something i could use to also achieve this? LOL
so if i go with the maft, then do i just take out all the shit thats in between the airfilter?
Maf, intake hose, bov recirc tube, Asumming you are getting the maf translator and upgrading the upper piping for the maf t.
What boost level is your turbo creeping too?
Yep answer this.
You should go ahead and get a 2g o2 housing and port the waste gate.
