Getting ready to tune.
agarcia892003
186
Feb 21, 2005
Green Bay, Wisconsin
ok guys I will be getting my FIC 550cc and my AEM Wideband late this week. Hopefully I will be getting my car tuned next week. I will be tuning with a SAFCII. Now my question is. how much boost can I run with all my upgrades and with stock internals? thanks in advanced guys.:thumb:
Start tuning with the boost low, and then slowly advance until you run either as much as you want or you start seeing timing being pulled (e.g. are knocking).
will an afcII count the knock? if so that's what i have. I will be getting it tuned at a shop..dyno tune.
The AFC will not give you a knock count. You need a logger of some sort, and most only log ignition timing. So you have to log the timing and see if the ECU pulls timing [ means it is more than likely getting knock and pulling timing as result ]
I believe Evoscan will also work on your ECU [ 98 and 99 ] and you can log knock with it too. You'd need the Evoscan software and the cable they sell.
EvoScan OBDII Mitsubishi MUTII DataLogger Scantool
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
