Getting Ready to install the following...
505talon
34
Sep 7, 2009
Tupelo, Mississippi
660cc injectors, 16g turbo, aem highflow fuel rail, fuel pressure regulator, and intake manifold. Any suggestions on intake manifolds? Any tips on what to do or not do before installing? Do I need a fuel management system? my intercooler on the car now is 2.5" core with 2.5" piping. should i also upgrade throttle body from stock? any advice, comments, and questions are welcome. I am getting ready to do it big time and want to make sure everything is right.
your 6-bolt (stock) intake manifold is good, no need to upgrade it when you need to spend the money on some electronics to control the amount of fuel going to the motor. ECMTuning, Inc.
your throttle body (TB) is 60mm which is good, you should upgrade to a 2g TB elbow though because the one on the 1g is very restrictive in the neck.
fuel controller and a fuel pump should be next on your cars grocery list and i wouldn't even bother installing the 660's until you get the fuel controller, your car won't be driveable its going to be running so rich. :coy:
:dsm:
I have the fuel pump already installed. 255lph. So the fuel management system should be next on my list? got cha. anything else?
