Yamadaaaa009
- 50
- 16
- Mar 7, 2023
Asia
I've been getting higher temps when sitting in traffic on a really hot day with a/c on, it goes up to 212f or sometimes when sitting for too long even goes up to 230f. Without a/c my temps are good. I'm using a cheap aluminum radiator and I noticed that there's a huge gap in between the a/c fan and the radiator so I was wondering if this might be causing it? Is this gap normal or the same in the stock radiator (I dont have my old radiator anymore so I couldn't check). Previously the fan motor was starting to fail on the a/c fan and we just newly replaced it, works fine until I get stuck in traffic where the temp goes higher and I have to turn off a/c just to lower it down. I'm also thinking of replacing both fans but my radiator fan works well, I've been stuck in traffic before on a really hot day when my a/c was broken and it never went past 194f. If not this, what else can I check?
Also don't mind the wires, I'm still sorting it out
Thanks!
Thanks!
. The only condition the temps get that high is when sitting in traffic on a hot day, but the temps go down once I get moving. I've sat in traffic for hours before on a cold rainy night and my temps didn't go that high. I'll try what you did and shave the standoffs so the fan assembly sits flush and see if it helps.
