FWD ECU in AWD 1g
Jeff822
636
Jan 22, 2006
Easton, Pennsylvania
My friend has a 1g awd, he wants to know if you could run the FWD ECU in his car, He swapped an automatic for a 5spd and now he needs an ECU and someone will give him one cheap but is FWD.
I was wondering will an ECU from a fwd work in my awd ### my friend ows me money and hes gona give me a comp for the money he ows me. Well he has a galant vr4 and the ecu worked fine in his Will it work in my GSX
I believe that the ECU you have would be a '90 FWD ECU. Pins 6 and 14 need to be swapped for it to work in your '91+ car. I had to do the same thing for My auto as it has the 450 injectors and the case had 91+ written on it, but the actual number was the same as your ECU if I remember correctly. If not, steve will let you know for sure.
Mike
Yes, that is a '90 FWD ECU and will, although not the best choice, work if you pop pins 6 and 14 from the connector and swap them. The software in the '90 ECUs isn't quite as polished as the later ones.
Do we really need two threads by different people on the same question?
http://www.dsmtuners.com/forums/showthread.php?p=50438590#post50438590
Steve
Steve
Thanks Bro for the clarification.:thumb: We will be swapping ours back to a '91+ when we can as the one I bought is not what I was looking for. And I noticed the same thing with the same question twice.
Mike
