2G Full Gasket rebuild kit 97 Eagle Talon Tsi
FredRider
5+ Year Contributor
127
30
Sep 11, 2019
Clewiston, Florida
Hello everyone so I’m finally getting close to finishing the rebuilding process on my 1997 Eagle Talon TSi 7 bolt but now I’m confused as to where I can get a full gasket rebuilt kit online. I’ve checked multiple threads but all of them talk about OEM, DNJ, Felpro, AJUSA and Cometic.
I know I can’t cheap out on the head gasket and I don’t plan on it just because of how much more money I’ve already put on the build. So if anyone could point me in the right direction that’d be great!
I found this on eBay but it comes with piston rings which I don’t need but comes with almost all the gaskets I need.
I was wondering if anyone has a list of all the gaskets I need because I can’t seem to find the list I made anywhere. Thanks!
Skip Ebay altogether and buy from reputable places like Extremepsi.com where you know the parts are quality.
Second this. Not that other suppliers and brands should be avoided, but I've ordered a wide variety of parts from Extremepsi.com and the quality is excellent and the shipping is fast.
Starting at the top of the motor
Valve cover gasket with tube seals and cam plug
Throttle body gasket
Fuel injector o-rings
biss screw seal (there is a plastic screw in the throttle body with a seal Under it)
Egr valve gasket
Intake manifold gasket
Exhaust manifold gasket
Turbo charger exhaust housing gasket
Valve stem seals
Cam seals
Can angle sensor seal and o-ring
Turbocharger gasket
Headgasket
Turbo drain line to turbo gasket
Turbo drain to oil pan gasket
Water pump gasket
Oil pump pulley seal
Oil pump gasket
Front crank seal
Oil filter housing gasket
Oil filter housing seal
Engine rear main seal
Oil pump pick up tube gasket
Oil pan gasket (technically there’s no gasket just rtv “
Cv axle seals (on transmission)
Down pipe exhaust gasket
Catalytic converter gasket
If you’re replacing all of the gaskets and seals you may also want to replace all of the coolant hoses. There are silicon hose kits sold on eBay that come with all of the coolant and heater hoses
Egr valve gasket
Valve stem seals
Turbocharger gasket
Headgasket
Water pump gasket
Oil pump gasket
Front crank seal
Oil pan gasket
I'll add cam seals and a half moon seal at the valve cover. There is also an oring at the CAS and a gasket
Egr valve gasket
Valve stem seals
Cam seals
Turbocharger gasket
Headgasket
Water pump gasket
Oil pump gasket
Front crank seal
Thank you for the help as well as to Pauley! I get busy with college and work and I completely forgot to get back and check but now that I have a list I can go ahead and start buying the right gaskets! Now that we're out for the Summer!
No. The 2Gb CAS body uses RTV to seal against the head.
