dwb
5+ Year Contributor
- 1,602
- 1,111
- Sep 9, 2021
Broomfield,
Colorado
I'm looking to upgrade the fuel system on my 1g. Currently running a stock system. It seems plenty has changed with injectors specifically so a lot of my research is outdated.
Applicable mods:
ECMLink
Rewired fuel pump
Fresh engine with 8.5:1 compression
Future mods: EVOIII 16G, Exhaust, Wideband
Goals:
~350 HP on 91 pump gas at 5600+ ft. elevation
Daily driver, so needs to idle and run smooth. Willing to sacrifice some performance for drivability if necessary.
I'm looking at the Walbro 255 LPH kit, FueLab 515 FPR kit. Any reason to shy away from either of these?
I'm undecided on injectors. That's why I come here. Do I go high-z or low-z? Is one easier to tune than the other? Does one type work better for a range of environmental factors, like below zero degree starts in the winter and 90+ degree days in the summer? Is there any difference in longevity?
Same goes for sizing. What tunes easy? Any environmental factors?
Initially I'm looking at something like the FIC 950cc low-z. Good, bad, ugly? What would you do in my shoes?
Applicable mods:
ECMLink
Rewired fuel pump
Goals:
, well - 20 years ago, I walk into Road Race engineering, tell them I have a Big16G and I want to upgrade the stock fuel pump - They they pull a Supra Green pump off the shelf, and hand it too me in a brown box.
