Resolved Fuel Injector tip
MEz
152
Nov 9, 2011
Gilbert, Arizona
Does anyone know if the pintle cap is necessary or is it a must? for a stock fuel injectors.
Solution
You guys are right the injectors didn't end up running right. After running them for about 40 straight miles last night the idle alternated from high to low in no particular pattern. I will be reinstalling the other injectors for the mean time while I order new caps from injector rehab.
Thanks guys
nm, I ended up installing the injectors with pintle caps without any problems so far.
Thanks guys
Solution
