Ludachris
Founder & Zookeeper
- 8,955
- 4,972
- Nov 12, 2001
Newcastle,
California
Like many other DSMers, I installed a steel braided fuel feed line from the pump to the rail to ensure I had enough volume. I used a -6 line. At some point here I'm going to be modifying my fuel system, adding a surge tank and changing over to E85. I might also use this time to swap out my steel braided line with a hard line to save a little weight and possibly go a little bit bigger.
What size would be sufficient? Any recommendations on flaring tools/other tools to do the job? I have a decent line bender. Anything else I should consider when doing hard lines?
That part slipped my mind.
