Calan
DSM Wiseman
- 7,250
- 400
- Jan 16, 2007
OKC,
Oklahoma
Has anyone built a custom high pressure line for a 1G?
I'd like to make a hard line from the rack to within about a foot of the pump, with a piece of rubber hose the rest of the way to allow for motor flex.
My thought is to either come directly off the rack (if I could find the right fitting), or couple into the existing line where the rubber mates up down by the rack. I want to run the hard line just above and parallel to the low pressure line in front of the motor mount, and then bend back toward the reservoir and join up with the flexible piece.
So, I have a couple of questions:
1. I'm a line fabbing newb, but understand the concept. Where can I find the raw tubing and an inexpensive bender? (I have a flaring tool).
2. Where can I find a fitting for the rack (or a fitting to mate up with the existing lower flare fitting), and how would I connect to the pump end? I was thinking maybe I could cut the rubber line coming off the pump about a foot back, and then somehow mate a flare fitting onto it which would join up with the new hardline portion.
I'm also thinking about just routing the hardline and making my bends, and then having a hydraulic shop (?) attach the fittings and pressure test the line.
Any ideas? I REALLY don't want that PS line running up and over the motor mount any more, and a new line would sit nicely right on top of the existing return line.
I have a bunch of pictures of the existing line routing, etc...but can't download them off my phone at the moment.
