Slanted J
Supporting VIP
- 131
- 3
- Feb 19, 2002
Janesville,
Wisconsin
All fuel cut threads are combined here.
I've tried doing a search but to no avail.
I was just wondering what Fuel Cut is. I've heard it tossed around alot, but do not actually know the details behind it. And, naturally, I can gather that its when the fuel is cut off, but when and why.
Thanx,
Jon
Thanx,
Jon
,then it will continue and cut again every 500 rpms
. I cant seem to figure this out.I have no boost leaks, held 20psi for 30seconds.It seems like it started having these problems after I changed by tb shaft seals.Also i have a joe p mbc and it is running 18 psi of boost set all the way down.If i take the bc off it will run 11psi,it doesnt cut out but it sputters at high rpms.Before i put in the 190lph fuel pump in,the boost controller set all the way down ran about 14psi. Please help!
I have the plugs gapped at .30 and im gonna try .28.
Tomorrow i am going to change the fuel filter and hope thats it. If thats not it what next?:
. at 12psi of boost it sounds more like the hks ssq, and i have the top spring screwed almost all the way out.Probably nothing just a thought.
