Resolved Forced Performance big t-28?
250rmike
May 1, 2003
pasadena, Maryland
first off i have already searched and didn't find the answer i was looking for.
i am getting ready to buy a 97 talon with some supporting mods(still has some work to do) the guys giving me a fp big t-28 with the car. what whp do these turbos push. i know fp has gotten into the high 11's but thats unlikely to achieve. basically how hard is it to get this turbo to push 300+whp on an awd. I'm just looking for a quick streetable daily driver. hopefully mid to upper 12's or should i sell this and go with a evo 3 or 20g? i know what the 20g is capable of and further down the road this may be an option. heres what on the car.
# B&M Short Throw Shifter
# Extreme Motorsports Stiff Shift Kit
# KYB AGX 4-way adjustable struts
# RMSD Front & Rear Sway Bars
# Dunlop SP9000 Tires (50%)
# Injen Intake
# Extreme Motorsports DIS Air Filter
# Extreme Motorsports 2.5" Downpipe
# Extreme Motorsports 2.5" High Flow Catalytic Converter
# Extreme Motorsports 2.5" Full Exhaust System with with 4" Tip
# Magnacore Spark Plug Wires
# Extreme Motorsports Full Upper & Lower I/C Pipes
# Steel Braided Clutch line
# Steel Braided Brake lines
# Power Slot Rotors Front & Rear
# Stillen Metal Matrix Brake Pads Front & Rear
# Clutch Masters Stage-3 Kevlar Clutch
# Xenon Arctic White Headlight & Foglights
# Unorthodox Racing Underdrive Pulley Set
i will be going 3" when i get some money together, along with a dsm link some injectors and fuel pump, and a fmic. thanks for any help
thanks for the link. ill defiantly be able to run the times i want but what hp can i expect out of it. running around 20psi for high boost ill run 15 for regular driving.(greddy profec b boost controller). again thanks for the help the car looks exactly like his also. same color and body
ill also have a evo manifold and gauges and ported o2 manifold
You will probably want to run more then 15 psi on the street (once you get fuel mods, logger & something to tune with). Im not exactly sure as I have the evoIII which flow abit more, but I would think at 15 psi you be in the 250 whp range & @ 20 psi you would probably be close to the 300 whp range (with a proper tune, which makes a huge difference), but then again this is just bench racing.
bench racing fine for now. im just talking 15 psi driving back and forth to work and for just driving around. i want to keep the boost down somewhat for less wear and tear. although i could just keep it out of boost but i know how i am. tuning wont be a problem, i know somewhat how to tune and my brother can tune well. he had a 400+whp del sol and my cousin used to own a shop. i was just getting a general idea of what to expect and whether i should sell the turbo and get a bigger one or if ill be happy with the t-28. for me i beleive the turbo will be good, atleast for the time being. plus i like the idea of a quicker spool, i hate turbo lag. thanks for the help
