flushing engine oil
bigtimegearhead
36
Jan 24, 2008
Romeoville, Illinois
When it comes to cleaning the oil system in my other cars I normally add a quart of trans fluid to the oil and run the car for about a day or two. I have also been using seafoam cause that stuff works awesome. I'm a little worried about doing this same thing on the talon becasue of the turbo. Do I have anything to really worry about or can I add a can of seafoam and drive the car real easy for a day then do the oil change??? What do you guys think??? :confused:
I wouldn't be running a day with seafoam in the oil, just add, run for a few minutes and change the oil again. I guess you could run with ATF for a day if your not getting into boost. I'm not sure how the turbo would like the ATF under load.
Why wouldn't you use Seafoam? Put in a half a quart 100-200 miles before an oil change drive it regulary and normal DD type of way and drain and fill with fresh.
Because if you run the engine for a small time with diluted oil it can damage the bearings. It is only made to be poured in, idled and drained out.
Well if you change your oil regularly and have a good crankcase ventilation setup you do not need to flush your motor. Adding a little oil while you are draining it can help get rid of some left over sludge in the oil pan, but other than that just change the oil.
Huh, thats the first I've heard of not using seafoam in oil. Only no, no's I could find where no longer then 100-200 miles, not to exceed .5 quarts, and no hard driving.
Another possible side effect was if it's the first few times using it on a old dirty engine could break up some of the sludge that had gathered and some leaks could appear and some tolerances could get bigger.
i wouldnt add this every oil change it isnt recommended i would stick with atf and not use seafoam and only do it every 15xxxx miles or once a year. atf is oil based with heavy detergents added to it.
I've added seafoam in the crank case once on a previous motor I had. Was the exact amount they specified and everything on the bottle. Let it idle for only 10 min or so with it in the crank case and then changed the oil.
About 50 miles later;
Knock Knock.
Who's there?
Rod knock.
Needless to say, I'll only use seafoam through vacuum from now on. :)
Knock Knock.
Who's there?
Rod knock.
I tried blaming seafoam for my mistakes before. Seafoam didn't give you rod knock. It was user error
It was either user error, or your running on borrowed time anyways, I always sea foam my vehicles annually. Usually sometime in early spring. Especially if its a vehicle I don't drive much in winter.
The fact that the bearings were in great shape prior to the seafoam treatment says otherwise.
Doesn't take rocket science on doing an oil change. So exactly what user error do you speak of?
I use seafoam every 2 oil changes. Except this time, it's no longer added in with my oil. As said before, adding it dilutes your engine oil, therefor reducing the friction protection for your bearings.
We use to, drain the pan but keep the oil filter on, then dump one quart of kerosene (or diesel fuel), one quart of ATF, and two quarts of non-detergent 30w and let this mix run for 15 minutes on idle only, then do the change.
Amazing the junk that this mix can get out of a dirty motor full of varnish and sludge.
You just DONT run a motor on super thinned oil..definitely asking for trouble.
Why do you use seafoam every 2 oil changes?
The user error I speak of can only be ideas I may have about the situation. Just my 2 cents really. But I doubt seafoam caused your rod knock. If you had a logger running maybe you should examine it and what your engine was doing before the rod knock occured.
Maybe you used the seafoam too often and that's what did your engine in?
What's so bad about regular oil changes that they need to be augmented with something else? Buy good oil and filters and you shouldn't have to worry about any of that stuff.
This is the way i look at it. Change the oil at normal intervals and use decent oil. There is no need to flush all the oil out. You will likely cause more issues instead of fixing anything.
If you normally run 15-40, diluting it will just bring it down to 10-30 region. I use diesel instead of atf, and I've gone as far as 50-50 diesel and oil while idling.
I don't think that the math works like that. 10-30 isn't just 15-40 that is diluted with a solvent. There are alot of other things at work in the oil that determine it's ability to be pressurized and lubricate. You guys can go ahead and flush your engines. I will just keep changing the oil and filters in my 180k mile vehicle. The first and last time that i ran a product like this i spun a bearing the very next day.
It's asking for trouble. If it runs fine, chances are its fine. Don't go fixing stuff that ain't broke.
If an engine is old and neglected maybe it will help. But otherwise it could mix improperly and cause a point of failure. It's a summer product. "summer the time it works, summer the time it doesn't." LOL
  • Wanted 6 bolt NT water pipe
    • chrisman287
