ECMlink first idle tuning the 2g
89coltgtnt
Aug 17, 2008
ringwood, New Jersey
hey all, i finally got another dsm. i started it up today, but it seems to be running rough. am i ready to take it for a spin
I'm not sure if you have yet, but there's very little information given in the log. Have you updated the ecu firmware recently? I'm not seeing a direct access tab. From what I'm seeing though, there's a bit of work to be done on getting the AFRest and your wideband to line up. It also seems that your wideband is reading 10.0 at idle? Should oscillate around 14.7 at idle. Make sure youre getting the correct fuel amounts and the gauges are working correctly before you take it out for a drive :)
I have not updated ecu firmware. I’m sorry I should have said for some reason the wideband jumps from 14-1 to 15-1 on the guage. I may have to double check that it’s getting the signal
for some reason link is saying my ecu does not support firmware upgrades.
    • george bromwell
    • pma1123
    • Sdcryan1
