ECMlink First Tuning Log
Chicken patty. I see you are using a AEM wb. What have you done to make sure your getting the correct log reading.
I also have a Greedy boost gauge that is suppose to log boost but I can't get it to log at all.
I'm going to fix the leaks I found with the BLT and going to swap to a set of 880 injectors and get them dialed in for idle.
I checked the base timing and its 5*
Compression on all 4 cylinders is 180 psi.
I have little to no discrepancy at all between link and my gauge. Example, gauge reads 14.7, log reads 14.6 or vice versa. Compared to a wideband on the dyno and they are accurate.
