finally got an engine
DDualan
98
Feb 19, 2012
Cumberland, Rhode Island
so i just picked up a stock 4g63t with 70k on it, what maintenance should i do before bolting this thing in ? i got a fresh timing belt and im getting fresh fluids.
The belts, water pump, hydraulic tensioner,the t-belt idler pulleys even the tensioner arm if worn.
If it's questionable I'd do it now while it's out & easier to do.
Check/replace the thermastat. Do a leak down test while you have it on the stand to make sure the HG is holding
If you want a fresh point to start from, replace every gasket and check every spec in the engine. If you are confident in where the car came from, just replace anything that is leaky, along with some minor mileage-related things like belts, the water pump, plugs, wires, check for boost leaks, and test most of the sensors.
Definatly the rear main, I would also inspect for leaks around the front case and oil filter housing
There is no oil pan gasket, just a sealant ;)
OEM came with sealant however they do sell oil pan gaskets made by felpro (not a cheap cork gasket either) and sure other companies too. I have 2 siting in my garage.. Lol
They do make gaskets for them, but that doesn't mean that you should use them. They seal like ass compared to a nice bead of grey rtv.
Lmao wow again with you... Seriously...Do it right and it won't leak. I use the gasket with black rtv and never had a problem with it leaking, and have put 50k+ on dsm motors... So it's all in the person doin it.
Lol do it right and it won't leak. I use the gasket with black rtv and never had a problem..
Well doing it right involves no gasket. Look at the pan rails, they have a valley that is made to hold the bead of rtv in place. Now look at a pan that is made for a gasket such as a transmission pan. There is a ridge that sticks up to dig into the gasket so that it doesn't squish out. Without the gasket will squish out before you get to the torque spec. Reaching the torque spec is critical because it stretches the bolt and allows it to he held in place. Without the use of loctite the bolts will back out after a while and you will have a leaky pan. Every single car that i've worked on over the years with a leaky pan was caused by installing a gasket. IF you correctly use the rtv and torque the bolts properly than it will never leak. You will literally have to cut the rtv out just to get the pan off.
Lol ok dude.... Rofl.
Just to be clear with you, I have never once used loctite on my oil pan bolts and they have never backed out on me, and as I said I have used both, sealant an gasket, PERSONAL EXPERIENCE, and have not had a leak. So if you did it and it leaked for you, as I said, you obviously didn't do it right..
I gave my opinion, he can use it as he wants, I didn't ask for nor do I need your 2cents.. Been building and messing around with dsm's for just short of 10years.. I know what I need to know and know what works and what don't already from trial and error...
