goonie90gsx
- 367
- 569
- Jul 14, 2009
Norton,
Ohio
I'm trying to get there haha hopefully next season I'll get it done.
The .70 Bullseye housings work very well for their size....don't let the smallish ".70" tag fool you. We had a .82 Garrett housing machined for this past season the same as richard33 and while the turbo is flowing better it's not like we gained a ton of MPH on top or anything.I'd like to see how much power could be gained from going with an open housing slightly larger than the .70 bep.
Concerning the average user- if you're not wringing the turbo for all it's worth and trying to get every last inch of flow out of it, the .70 Bullseye housing is all you'll ever need. For a street car a .82 or larger single-scroll housing may add more lag than you'll stand to gain in airflow.
This is the coolest thing I've seen in my lifeI'm Running a Holset hx40 with a Bep .70ar housing.. Its a hybrid with a billet 67mm compressor wheel and a 65mm turbine. I have been very impressed with this turbo. I didn't even have an hx40 core to send them. I just sent them my Bep housing and for around $650 they sent me back the complete turbo. They said it should flow 89lbs/MIN. I'm very happy with this turbo.
. But quick question. When you say "they", who exactly are you referring to? I may have missed it somewhere.Video description says 42psi@AWD Sebring, how much boost were you running on the dyno? What's the spool time with the larger wheel?
Btw, love the car, total sleeper.
jakelandry... I've machined over a dozen t3 and t4 housings for other people as well as my own turbo to make a garrett turbine housing hold a holset CHRA/compressor , mine is over the 50k mile mark now and still going well.. I used about .007" more clearance on the blade to housing clearance than what the holset originally was setup with.... basically just used safe numbers from what I learned way back in the day at Majestic turbo leanrning to machine housings. it works well I love mine and everyone I've done one for in the past seemed to be as satisfied as I was with mine.. go for it!!
Wondering what info this is based on regarding airflow accuracy, boost pressure, etc.They said it should flow 89lbs/MIN.
Thanks Bud. Sorry I was referring to turbo lab.This is the coolest thing I've seen in my life. But quick question. When you say "they", who exactly are you referring to? I may have missed it somewhere.
Dave's 66/84/86.6mm extended-tip KTS compressor just logged over 80 lb/min at 40psi for the very first time at the tail end of this past season...and that's with about the best-flowing turbine wheel and T3 turbine housing available for such a compressor used in a Holset on a car with about the best supporting mods being utilized. I find it hard to believe the 67/89mm wheel is SO much of an improvement that it's worth another 9 lb/min of airflow.
The boost spiked to 42 and fell to 40. It spools right around 5,400. and thanks I appreciate it..@AWD Sebring, how much boost were you running on the dyno? What's the spool time with the larger wheel?
wow that's awesome!! Such a unique set up.I'm Running a Holset hx40 with a Bep .70ar housing.. Its a hybrid with a billet 67mm compressor wheel and a 65mm turbine. I have been very impressed with this turbo. I didn't even have an hx40 core to send them. I just sent them my Bep housing and for around $650 they sent me back the complete turbo. They said it should flow 89lbs/MIN. I'm very happy with this turbo.You must be logged in to view this image or video.You must be logged in to view this image or video.
