Fastener Torque Values [Merged 3-9] value tightness torques specs specifications
GreddySpyder
414
Oct 21, 2002
Alabama
I changed my leaky oil pan gasket not long ago and it is still leaking. I used red rtv as the gasket and ran a nice continuous bead around the whole pan making a circle around each bolt hole. I think the two mistakes I made were not waiting for the RTV to dry before putting the pan back on, and I think I tightened the bolts too much ( I ended up breaking one of them).
I'm gonna buy a torque wrench and make sure they are right this time... how much torque do the pan bolts require? How long should I let the RTV dry this time before putting the pan back on?
Hi all,
The recommended torque spec that is in my shop manual seems way too low for the bolts that connect the turbo to the manifold. Does anyone know what the torque spec is for these bolts?
thanks
meek
Damn..really? Surpise, the manual is right then! Those things were very difficult to remove so I figured they were torqued very high. I guess i'm wrong then.
If you are talking about the four bolts that secure the flex plate to the torque converter on a 2G turbo automatic transmission, it is 33-38 ft. lbs.
that picture for the main bearings is from the 1g 92 and a half to 94 manual picture. I'm looking in a 90 and 91 manual and it does not show a torque sequence for the main bearings..... what the heck....... am i blind?
Heres some more guys:
Sensors:
-Engine coolant temp. sensor: 15-29 ft. lbs.
-Fuel guage unit: 1.4-2.2 ft. lbs.
-Oil level guage mounting bolt: 9-11 ft. lbs.
-Oil pressure guage unit: 6-9 ft. lbs.
-Crank angle sensor: 7-9 ft. lbs.
Engine supports/cross members:
-Left engine suport bracket: 22-30 ft. lbs.
-Engine mount bracket to bracket nut or bolt: 12-19 ft. lbs.
-Center member install bolt: 58-72 ft. lbs.
Exhaust:
-Exhaust to manifold (N/T): 29-43 ft. lbs.
-Heat sheild to manifold: 9-11 ft.lbs.
-Exhaust manifold to turbo: 40-47 ft. lbs.
-Exhaust manifold to head: 18-22 ft. lbs.
-O2 to DP studs: 29-43 ft. lbs.
-O2 sensor: 29-36 ft. lbs.
Misc. Engine:
-Wastegate actuator: 7-9 ft. lbs.
-Check valve (Turbo): 22-25 ft. lbs.
-Timing belt rear cover: 7-9 ft. lbs.
-6-Bolt connecting rod cap: 36-38 ft. lbs.
-7-Bolt connecting rods: 18 ft. lbs. + 1/4 turn (torque -to-yeild bolts)
-Rocker cover: 2-3 ft.lbs.
-Spark plug galley cover: 2-3 ft. lbs.
Misc. oil stuff:
-Oil return line to oil pan (Turbo): 6-7 ft. lbs
-Oil pipe to engine (Turbo): 10-14 ft. lbs.
-Oil screen nut or bolt: 11-16 ft. lbs.
-Oil pump sprocket: 36-43 ft. lbs.
-Oil pump driven gear: 25-29 ft. lbs.
-Front case: 14-16 ft. lbs.
-Oil filter bracket: 11-16 ft. lbs.
-Engine oil cooler mounting nut: 6-9 ft. lbs.
-Oil banjo bolt: 20-25 ft. lbs.
-Oil jets: 22-25 ft. lbs.
Pulleys:
-Crank pulley: 14-22 ft. lbs.
-Auto tensioner: 14-20 ft. lbs.
-Timing belt tensioner pulley: 31-40 ft. lbs.
-Timing belt idle pulley: 25-30 ft.lbs.
Intake:
-Intake manifold stay bolt: 18-22 ft. lbs.
-Throttle body stay: 11-16 ft. lbs
Coolant Misc.
-Engine cooler pipe to engine front case: 29-33 ft lbs.
-Water banjo bolt: 25-36 ft. lbs.
Water Pump:
-Water outlet: 12-14 ft. lbs.
-Water pipe-to-engine: 10-14 ft. lbs.
-Water pipe-to-turbo: 25-36 ft. lbs.
-Water pump bolt (4T): 9-11 ft. lbs.
-Water pump bolt (7T): 14-20 ft. lbs.
-Water pump pulley: 6-7 ft. lbs.
This thread is awesome, keep it coming. As soon as it's a few pages long i'll print it out for a spot in my "quick reference" binder where i keep as much pertinent but as little "useless" information as possible.
I'm working on the list for 2Gs slowly guys so please bare with me...
Suspension:
Front(AWD):
1990-1994:
-Axle Shaft Nut: 144-188 ft. lbs.
-Ball Joint Stud Nut: 43-52 ft. lbs.**
-Brake Caliper Bolt: 58-72 ft. lbs.
-Clamp-to-Cross-Member Nut/Bolt:
Bolts (short): 58-72 ft. lbs.**
Bolts (long #7 on bolt head): 58-72 ft. lbs.**
Bolts (long #10 on bolt head): 72-87 ft. lbs.**
Nut: 25-34 ft. lbs.**
-Control Arm-to-Cross-Member bolt: 72-87 ft. lbs.**
-Cross-Member Brace Bolt: 51-58 ft. lbs.
-Cross-Member #2 Rear Bolt: 58-72 ft. lbs.
-Cross-Member Bolt (left):
Front: 58-72 ft. lbs.
Rear: 51-58 ft. lbs.
-Stabilizer Bar Link Nut: 25-33 ft. lbs.
-Stabilizer Bar Mounting Bracket Bolt: 22-30 ft. lbs.
-Strut Shaft (Self-locking nut): 43-51 ft. lbs.
-Strut-To-Body Nut: 29-39 ft. lbs.
-Strut-To-Knuckle Bolt: 80-101 ft. lbs.
-Tie Rod Nut: 17-25 ft. lbs.
** Tighten to specs. with vehicle at normal operating height.
1995-:
-Axle Nut: 145-188 ft. lbs.
-Caliper Assembly Mounting Bolt: 65 ft. lbs.
-Center Member To Body: 58-65 ft. lbs.
-Compression Lower Arm To Cross-Member: 60 ft. lbs.
-Compression Lower Arm To Knuckle: 43-52 ft. lbs.
-Drive Shaft Nut: 145-188 ft. lbs.
-Dust Shield To Knuckle: 6.5 ft. lbs.
-Hub Assembly To Knuckle: 65 ft. lbs.
-Hub Nut: 145-188 ft. lbs.
-Joint Assembly & Gear Box Bolt:13 ft. lbs.
-Knuckle To Compression Lower Arm: 43-52 ft. lbs.
-Knuckle Upper Mounting: 21 ft. lbs.
-Lateral Lower Arm To Cross-Member: 71-85 ft. lbs.
-Lateral Lower Arm To Damper Fork: 65 ft. lbs.
-Lateral Lower Arm To Knuckle: 43-52 ft. lbs.
-Power Steering Brackets To Cross-Member: 51 ft. lbs.
-Power Steering Oil Pump To Bracket: 21-29 ft. lbs.
-Power Steering Pipe Connections: 11 ft. lbs.
-Power Steering Pressure Hose To Pump (Non-Turbo): 42 ft. lbs.
-Power Steering Pressure Hose to Pump (Turbo): 13 ft. lbs.
-Stabilizer Bar Bracket: 28 ft. lbs.
-Stabilizer Link To Stabilizer Bar: 28 ft. lbs.
-Stabilizer Link To Dampener Fork: 28 ft. lbs.
-Stay To Cross Member: 51-58 ft. lbs.
-Strut Top End Nut: 16 ft. lbs.
-Strut Lower Mounting: 75 ft. lbs.
-Strut Upper Mounting Nut: 32 ft. lbs.
-Tie Rod End To Knuckle: 21 ft. lbs.
-Upper Arm To Knuckle: 21 ft. lbs.
-Wheel Lug Nuts: 88-108 ft. lbs.
Rear(AWD):
1990-1994:
-Axle Shaft Companion Flange Nut-To- Rear: 116-159 ft. lbs.
-Ball Joint Nut: 43-52 ft. lbs.
-Brake Tube Bracket-To-Rear Shock Absorber: 12-19 ft. lbs.
-Companion Flange-To-Drive Shaft: 40-47 ft. lbs.
-Lower Arm Ball Joint To Knuckle: 43-52 ft.lbs.
-Hub Assy. To Knuckle: 144-188 ft. lbs.
-Joint Assy.: 11-16 ft. lbs.
-Lower Arm Clamp To Cross-Member (Bolt): 58-72 ft. lbs.
-Lower Arm Clamp To Cross-Member (Nut): 25-34 ft. lbs.
-Caliper Mounting Assy. Bolt: 58-72 ft. lbs.
-Center Bearing Bracket: 26-33 ft. lbs.
-Center Member To Body: 58-72 ft. lbs.
-Drive Shaft Nut: 144-189 ft. lbs.
-End Plug: 36-51 ft. lbs.
-Feed Tubes: 9-13 ft. lbs.
-Gearbox To Bracket To Cross-Member: 43-58 ft. lbs.
-Knuckle To Strut Assy. 80-101 ft. lbs.
-Lower Arm To Knuckle: 43-52 ft.lbs.
-Lower Arm To Cross-Member: 65-80 ft.lbs.
-Upper Arm To Cross-Member: 101-116 ft.lbs.
-Upper Arm To Knuckle: 43-52 ft.lbs.
-Cross-Member Bracket To Body: 51-61 ft.lbs.
-Cross-Member Bracket To Cross-Member: 80-94 ft.lbs.
-Shock Absorber Upper Mounting Nut: 29-36 ft.lbs.
-Shock Absorber Lower Mounting Nut: 58-72 ft.lbs.
-Strut Top-End Nut: 43-51 ft. lbs.
-Strut Upper Mounting Nut: 29-39 ft. lbs.
-Stabilizer Link To Stabilizer Bar: 25-33 ft.lbs.
-Stabilizer Bar Bracket: 22-30 ft. lbs.
-Stabilizer Link: 25-33 ft. lbs.
-Wheel Bearing Nut: 144-188 ft.lbs.
-Tie Rod End Ball Joint: 17-25 ft. lbs.
-Tie Rod End To Rack: 58-72 ft. lbs.
1995-:
Axle Nut: 145-148 ft. lbs.
Brake Caliper Assembly: 36-43 ft. lbs.
Differential Mounting Bracket To Cross Member: 72 ft. lbs.
Differential Mounting Bracket To Differential: 65 ft. lbs.
Differential Mount Support Bolts: 33 ft. lbs.
Lower Arm To Cross Member: 71 ft. lbs.
Lower Arm To Knuckle: 71-72 ft. lbs.
Lower Shock Absorber Mounting Bolt: 71-72 ft. lbs.
Piston Rod Tightening Nut: 16 ft. lbs.
Propeller Shaft To Differential: 22-25 ft. lbs.
Rear Hub To Knuckle: 54-65 ft. lbs.
Stabilizer Bar Mounting Bracket: 7-10 ft. lbs.
Stabilizer Link To Lower Arm: 28 ft. lbs.
Toe Control Arm To Cross Member: 50-56 ft. lbs.
Toe Control Arm To Knuckle: 20-21 ft. lbs.
Trailing Arm To Body: 99-114 ft. lbs.
Trailing Arm To Knuckle: 85-101 ft. lbs.
Upper Arm To Knuckle: 71 ft. lbs.
Upper Arm Bracket To Body: 28 ft. lbs.
Upper Arm Bracket To Upper Arm: 41 ft. lbs.
Upper Shock Absorber Mounting Nut: 32 ft. lbs.
Drive Shaft/U-joints:
1990-1994:
-Center Support Bearing Mount Nut: 22-29 ft. lbs.
-CV Joint Nut: 22-29 ft. lbs.
-Drive Shaft Companion Flange Nut: 116-159 ft. lbs.
-Drive Shaft-To-Differential Flange Nut: 22-25 ft. lbs.
-Drive Shaft Yoke Nut: 116-159 ft. lbs.
1995-:
Transfer Case:
1990-1994:
-Drain/Fill Plug: 22-26 ft. lbs.
-Driven Bevel Gear (Lock Nut): 103-118 ft. lbs.
-Extension Housing Bolt: 11-16 ft. lbs.
-Front Exhaust Pipe Mounting Bracket Bolt: 15-22 ft. lbs.
-Front Exhaust Pipe (Self-Locking Nut): 22-30 ft. lbs.
-Transfer Case Adapter Bolt: 26-31 ft. lbs.
-Transfer Side Cover Bolt: 26-31 ft. lbs.
-Transfer Case Assy. Mounting Bolt: 40-43 ft. lbs.
-Case Cover Bolt: 71-89 in. lbs.
1995-:
Auto Trans/Transaxle:
1990-1994:
-Sprang Rod Support: 15-19 ft. lbs.
-Tie Rod End To Knuckle: 17-25 ft. lbs.
-Transaxle Control Cable Adjusting Nut: 7-10 ft. lbs.
-Transaxle Control Cable To Body: 7-10 ft. lbs.
-Transaxle Mount Bracket To Transaxle: 43-58 ft. lbs.
-Transfer Lock-Nut: 145-166 ft. lbs.
-Pressure Check Plug: 6-7 ft. lbs.
-Pulse Generator: 7-9 ft. lbs.
-Pump Housing To Reaction Shaft Support: 7-9 ft. lbs.
-Selector Lever Assembly: 7-10 ft. lbs.
-Shift Lock Cable To Selector Lever Assembly: 3-4 ft. lbs.
-Speedometer Sleeve Locking Plate: 2-4 ft. lbs.
-End Clutch Cover: 5-6 ft. lbs.
-Hose Bracket: 2-4 ft. lbs.
-Inhibitor Switch: 7-9 ft. lbs.
-Lever Assembly To Bracket Assembly: 10-14 ft. lbs.
-Lock Plate: 26-32 ft. lbs.
-Manual Control Lever Nut: 13-15 ft. lbs.
-Manual Control Shaft Setscrew: 6-7 ft. lbs.
-One-Way Clutch Outer Race: 18-25 ft. lbs.
-Ball Joint To Knuckle: 43-52 ft. lbs.
-Bearing Retainer: 12-15 ft. lbs.
-Bell Housing Cover To Engine: 7-9 ft. lbs.
-Clamp To Body: 3-4 ft. lbs.
-Converter Housing: 14-16 ft. lbs.
-Drain Plug: 22-25 ft. lbs.
-Drive Plate To Converter: 34-38 ft. lbs.
1995-:
-Air Intake Hose Connections: 3 ft. lbs.
-Bell Housing Cover: 7-9 ft. lbs.
-Compression Arm Connection: 44-52 ft. lbs.
-Cross-Member To Body: 51-58 ft. lbs.
-Cross-Member To RH Stay: 51-58 ft. lbs.
-Cross-Member To Transaxle: 42 ft. lbs.
-Damper Fork to Lateral Lower Arm: 65 ft. lbs.
-Drive Plate Connecting Bolt: 33-38 ft. lbs.
-Lateral Lower Arm Connection: 44-52 ft. lbs.
-Mounting Bracket To Body: 51 ft. lbs.
-Mounting Bracket To Transaxle: 42 ft. lbs.
-Oil Level Gauge Bracket: 17 ft. lbs.
-Rear Roll Stopper Bracket: 51 ft. lbs.
-Stabilizer Link To Damper Fork: 29 ft. lbs.
-Starter Motor to Transaxle: 22 ft. lbs.
-Tie Rod End Nut: 18-25 ft. lbs.
-Torque Converter Connecting Bolt: 33-38 ft. lbs.
-Transaxle Control Cable Connection: 7 ft. lbs.
-Transaxle Lower Coupling Bolts: 35 ft. lbs.
-Transaxle Upper Coupling Bolts: 22-25 ft. lbs.
Brakes:
1990-1994:
-Backing Plate Bolts: 36-43 ft. lbs.
-Bleed Screws: 8-11 ft. lbs.
-Brake Booster To Dash: 18-25 ft. lbs.
-Brake Hose To Rear Caliper Banjo Bolt: 5-7 ft. lbs.
-Caliper Support To Front Axle: 58-72 ft. lbs.
-Caliper Support To Rear Axle: 36-43 ft. lbs.
-Master Cylinder To Brake Booster: 6-9 ft. lbs.
-Wheel Cylinder: 6-9 ft. lbs.
1995-1996:
Front:
-Bleed Screws: 5-7 ft. lbs.
-Caliper Guide & Lock Pins: 54 ft. lbs.
Rear:
-Brake Hose-To-Rear Caliper Banjo Bolt: 18-25 ft. lbs.
Rear MR45V & MR45S 20 ft.lb
MR58V 32 ft.lb
-Caliper Support-To-Rear Axle: 36-43 ft. lbs.
Clutch Pedal Assy.:
1990-1994:
-Clutch Pedal Bracket: 6-9 ft. lbs.
-Clutch Pedal Support Bracket: 6-9 ft. lbs.
-Clutch Pedal To Support Bracket: 14-18 ft. lbs.
1995-:
Clutch Slave Cylinder:
1990-1994:
-Clutch Release Cylinder: 11-16 ft. lbs.
-Clutch Tube Flare Nut: 9-12 ft. lbs.
1995-:
Computers/Control Systems/Sensors:
All Years:
-Coolant Temperature Switch: 22-29 ft. lbs.
-EGR Valve Mounting Bolt: 16 ft. lbs.
-EGR Temp. Sensor: 7.3-8.6 ft. lbs.
-Engine Coolant Temperature Sensor: 15-29 ft. lbs.
-ISC Servo Mounting Screws: 1.8-3.3 ft. lbs.
-TPS Mounting Screws: 1.1-1.8 ft. lbs.
-Stop Lamp Switch: 7-11 ft. lbs.
-Back-up Lamp Switch: 22-25 ft. lbs.
-Oil Level Gauge Mounting Bolt: 9-11 ft. lbs.
-Oil Pressure Gauge Unit: 6-9 ft. lbs.
-Crank Angle Sensor: 7-9 ft. lbs.
-O2 Sensor: 29-36 ft. lbs.
-Cooling Fan Switch: 8-18 ft. lbs.
1990-1994:
-Fuel Gauge Unit: 1.4-2.2 ft. lbs.
1995-:
-Fuel Gauge Unit (FWD): 1.8 ft. lbs.
-Fuel Gauge Unit (AWD): 36 ft. lbs.
Differential Assy.:
1990-1994:
-Hanger Installation Bolt: 7-11 ft. lbs.
-Hook Installation Bolt: 7-11 ft. lbs.
-Piston Rod Nut: 14-18 ft. lbs.
-Rear Brake Assembly Installation Bolt: 36-43 ft. lbs.
-Differential Support Member To Body: 80-94 ft. lbs.
-Differential Carrier To Differential Support Member: 58-72 ft. lbs.
-Differential Carrier To Propeller Shaft: 22-25 ft. lbs.
-Lateral Rod Mounting Nut (Body Side): 58-72 ft. lbs.
-Lateral Rod Mounting Nut (Axle Beam Side): 72-87 ft. lbs.
-Trailing Arm Mounting Bolt: 72-87 ft. lbs.
-Trailing Arm To Cross Member: 101-116 ft. lbs.
1995-
Exhaust:
1990-1994:
-Exhaust Pipe Clamp Bolt: 22-29 ft. lbs.
-Exhaust Pipe Support Bracket: 22-30 ft. lbs.
-Exhaust Pipe-to-Hanger: 7-11 ft. lbs.
-Exhaust-To-Manifold (N/T): 29-43 ft. lbs.
-Heat Shield-To-Manifold: 9-11 ft.lbs.
-Exhaust Manifold-To-Turbo: 40-47 ft. lbs.
-Exhaust Manifold-To-Head: 18-22 ft. lbs.
-O2-To-Turbo Studs: 29-43 ft. lbs.
1995-:
-Exhaust Manifold-To-Head: (small studs)20 ft. lbs. & (2 large outer studs) 21 ft. lbs.
Fuel Delivery/Air Induction:
1990-1994:
-Accelerator Cable Adjustment Bolts: 3-4 ft. lbs.
-Air Bypass Valve: 11-16 ft. lbs.
-Air Hoses (Hose Clamps): 3 ft. lbs.
-Air Pipe Mounting Bolts: 9-11 ft. lbs.
-Drain Plug: 11-14 ft. lbs.
-FPR Installation Bolts: 6-7 ft. lbs.
-Fuel Rail Installation Bolts: 7-9 ft. lbs.
-Ground Plate Mounting Screws: 1.5-2 ft. lbs.
-High Pressure Hose-To-Fuel Filter: 18-25 ft. lbs.
-High Pressure Hose-To-Fuel Rail: 3-4 ft. lbs.
-High Pressure Hose-To-Fuel Pump: 22-29 ft. lbs.
-Intercooler-To-Body: 9-11 ft. lbs.
-Main Pipe-To-Fuel Filter: 22-29 ft. lbs.
-Main Pipe-To-High Pressure Hose (FWD): 18-25 ft. lbs.
-Main Pipe-To-High Pressure Hose (AWD): 22-29 ft. lbs.
-Throttle Body Stay Mounting Nuts: 11-16 ft. lbs.
-Throttle Body-To-Surge Tank Bolts: 11-16 ft. lbs.
-Intake Manifold Mounting Bolt (M8): 11-14 ft. lbs.
-Intake Manifold Mounting Nut & Bolt (M10): 22-30 ft. lbs.
1995-:
-Intake Manifold To Head: 14 ft. lbs.
-Electric Fuel Pump: 1.8 ft. lbs.
Ignition:
1990-1994:
-Crank/Cam Position Sensor Mounting Nut: (TDC): 7.5-8.5 ft. lbs.
-Spark Plugs: 15-21 ft. lbs.
1995-:
Manual Trans./Transaxle:
1990-1994:
-Bearing Retainer Bolt: 11-15 ft. lbs.
-Bellhousing Cover: 7-9 ft. lbs.
-Fulcrum: 25-30 ft. lbs.
-Input Shaft Locknut: 102-115 ft. lbs.
-Poppet Plug: 43-52 ft. lbs.
-Rear Housing Cover Bolt: 11-15 ft. lbs.
-Restrict Ball Assembly: 11-15 ft. lbs.
-Stopper Bracket Bolt: 11-15 ft. lbs.
-Transaxle Bracket: 43-58 ft. lbs.
-Transaxle Case Tightening Bolt: 26-30 ft. lbs.
-Transfer Assembly Mounting Bolt: 40-43 ft. lbs.
1995-:
-Back-Up Lamp Switch: 22 ft. lbs.
-Bearing Retainer Bolt: 14 ft. lbs.
-Clutch Cover Assembly: 11-16 ft. lbs.
-Compression Lower Arm: 44-52 ft. lbs.
-Flywheel Bolts: 55 ft. lbs.
-Lower Arm Ball Joint To Knuckle: 44-52 ft. lbs.
-Poppet Plug: 27 ft. lbs.
-Rear Housing Cover Bolt: 14 ft. lbs.
-Restrict Ball Assembly: 24 ft. lbs.
-Shift & Select Cable To Transaxle: 11-16 ft. lbs.
-Speedometer Sleeve Bolt: 3 ft. lbs.
-Starter Motor Mounting Bolt: 40 ft. lbs.
-Stop Lamp Switch: 24 ft. lbs.
-Tie Rod End To Knuckle: 18-24 ft. lbs.
-Transaxle Case Tightening Bolt: 29 ft. lbs.
-Transaxle Mounting Bolt: 35 ft. lbs.
-Transfer Assembly Mounting Bolt: 40-44 ft. lbs.
Steering:
1990-1994:
-Power Steering Bracket: 25-33 ft. lbs.
-Air Bag Retaining Bolts (Driver): 4 ft. lbs.
-Steering Wheel Nut: 30 ft. lbs.
Manual Steering:
P/S:
1995-:
95 Steering Column
Cooling:
1990-1994:
-Radiator Upper Insulator: 7-10 ft. lbs.
-Water Pipe "A" Mounting Bolt: 7-9 ft. lbs.
-Water Pipe "A" To Turbo: 25-36 ft. lbs.
-Water Pipe "B" To Turbo: 25-36 ft. lbs.
-Water Pipe "B" To Water Inlet Pipe: 29-36 ft. lbs.
-Engine Cooler Pipe-To-Engine Front Case: 29-33 ft lbs.
-Water Banjo Bolt: 25-36 ft. lbs.
1995-:
Water Pump:
1990-1994:
-Water Outlet: 12-14 ft. lbs.
-Water Pipe-To-Engine: 10-14 ft. lbs.
-Water Pipe-To-Turbo: 25-36 ft. lbs.
-Water Pump Bolt (4T): 9-11 ft. lbs.
-Water Pump Bolt (7T): 14-20 ft. lbs.
-Water Pump Pulley: 6-7 ft. lbs.
1995-:
Misc. Engine:
1990-1994:
-Starter Motor: 20-25 ft. lbs.
-Wastegate Actuator: 7-9 ft. lbs.
-Check Valve (Turbo): 22-25 ft. lbs.
-Timing Belt Rear Cover: 7-9 ft. lbs.
-6-Bolt Connecting Rod Cap: 36-38 ft. lbs.
-Rocker Cover: 2-3 ft.lbs.
-Spark Plug Galley Cover: 2-3 ft. lbs.
-Balance Shaft Sprocket: 31-35 ft. lbs.
1995-:
Engine Internals:
All Years:
1990-1994:
-Crankshaft Main Bearing Caps: 51 ft. lbs.
1995-1999:
-Crankshaft Main Bearing Caps: 18 ft. lbs. +90*(1/4 turn)
-Camshaft Bearing Cap Bolt: 14-15 ft. lbs.
-Camshaft Sprocket: 65 ft. lbs.
-Connecting rod Bearing Cap: 14.5 ft. lbs. +90*(1/4 turn)
Engine Supports/Cross Members:
1990-1994:
-Left Engine Support Bracket: 22-30 ft. lbs.
-Engine Mount Bracket-To-Bracket Nut/Bolt: 12-19 ft. lbs.
-Center Member Install Bolt: 58-72 ft. lbs.
1995-:
Misc. Oil:
1990-1994:
-Oil Pump To Bracket: 25-33 ft. lbs.
-Oil Reservation Bracket Bolt: 7-10 ft. lbs.
-Oil Pipe-To-Turbo: 20-25 ft. lbs.
-Oil Return Line-To-Oil Pan (Turbo): 6-7 ft. lbs
-Oil Pipe-To-Engine (Turbo): 10-14 ft. lbs.
-Oil Screen Nut or Bolt: 11-16 ft. lbs.
-Oil Pump Sprocket: 36-43 ft. lbs.
-Pressure Hose To Oil Pump: 10-15 ft. lbs.
-Oil Pump Driven Gear: 25-29 ft. lbs.
-Front Case: 14-16 ft. lbs.
-Oil Filter Bracket: 11-16 ft. lbs.
-Engine Oil Cooler Mounting Nut: 6-9 ft. lbs.
-Oil Banjo Bolt: 20-25 ft. lbs.
-Oil Jets: 22-25 ft. lbs.
1995-:
Pulleys:
1990-1994:
-Crank Pulley: 14-22 ft. lbs.
-Auto Tensioner: 14-20 ft. lbs.
-Timing Belt tensioner pulley: 31-40 ft. lbs.
1995-:
This is what I have added so far. It includes what has been posted above. I have added links to a couple new diagrams, and I will be making links to lots more diagrams that are in my Photobucket account...
Thanks for the kind words.
I've added in some new stuff to the list guys. Once I have completed it, I'm going to make it MUCH easier to navigate it between sections/generations of DSM's.
Just curious where you got these from because in my Chilton's (for a 2g) for the exhaust manifold to head nuts it says to torque them down to 36 ft/lbs. Now I torqued them down to 21 ft/lbs just so I don't snap off another stud inside the head, but what ft/lb is correct?
    • Sdcryan1
