2G Fans not working
JaKee003
55
Feb 4, 2017
Keller, Texas
I’ve been having some overheating problems on my gst, I noticed that the radiator fans do not come on even after running for 20+ minutes, I also tried turning on the AC and the fan didn’t work. I have a 99 gs that has both fans in decent condition and I was wondering if those would work for my gst? Also is their a proper way to burp the system....I jacked up the front of the car but I don’t know if there’s a better way to do it
One fan is for the motor,/ overheating fan. The other is the ac fan. I'd go grab two new thermostats, put it in and that should fix the issue. I've had a bad thermostat so that's why I suggested buy two. Make sure the wiring is plugged in, off the thermostat housing as well.
Burping the system. Umm I basically put in coolant and use my large frame to bounce the from end for a few seconds, add more and repeat. Let car run for what 30 seconds, so it dont get to hot, bounce car again cap off, and add coolant till it's full. :thumb:
Fans from a GS to a GST would work. Connectors were the same and the fans were pretty much the same. If they're not kicking on though, that sounds like an electrical issue to me. Doesn't seem like the ECU is getting or sending a signal to kick them on. You can test the fan by grounding the black wire and then running a jumper from one of the colored wires to the positive post on your battery. That'll kick it on, or, it if's bad - not.
Yea I tried that yesterday and it worked so it’s not the fan....so now I know it’s an electrical problem but don’t really know where to start
