External Wastegate air fitting?
JDR7919
301
Jan 1, 2005
Titusville, Florida
Hey guys I was wondering if there is a way to adjust my tial waste gate so the air fitting is not right next to my ex manifold?
Yes, it is easy. You have to take the top off, take the spring and then diaphragm out. There is a nut at the base, loosen it and turn the bottom, until you get the fitting in desired location.
Sweet!! Thanks
When you take the top off, I suggest using some sort of clamps/adj./ with rubber ends. Saves a lot of time and makes putting it back together easy, furthermore PREVENTS you of ####ing up the diaphragm/ask me how I know/. If you try and completely remove diaphragm, those small allen key studs on has to be put back together with blue locktite!!!
