exhaust eliminating cat how to run w/out codes
greentsiawd13
57
Oct 15, 2008
chicago, Illinois
95 awd want to run custom exhaust w/out a cat for racing what do i have to get to control the computer so it doesnt run lean or rich and what every else might arise with the setup
(apex the way?) new to the tuning world :aha:
So when I put my cat-elim dp on I shouldn't have a problem? I was gonna use the bung on my exhaust for my wbo2
If you don't want to have the second o2 sensor ( the one downstream of the CAT) you can build an electrical circuit that makes the computer think second o2 sensor is still there.
http://www.dsmtuners.com/forums/art...making-your-own-rear-o2-bypass-simulator.html
check this^ out
ya i ran w/o a cat for years and never got a cel from the 2nd O2 sensor. Just make a O2 bypass sim if you ever get a cel
Rear o2 sensor does not effect fuel mixture
The Rear o2 sensor just "tattle-tales" on the catalystic converter's existence to the ECU. Car's performance doesn't change with or without it. I have a straight pipe(no cat) and o2 sensor removed and zip-tied to a hangar, out of the way, and the o2 bung plugged with a bolt. No check engine light(CEL) for two years now. When i first removed the "cat" I did have a CEL, and thats why I removed the sensor and plugged the bung.
