evolll porting question
rowdygst
230
Jan 12, 2011
san antonio, Texas
ok, i picked up this turbo today, and i noticed the echaust haousing was missing the divider between the echaust wheel and the wg, i took a closer look and it was removed by some orting it or something, you definatly see that it was done with a carbide bit. so my question is this, does it affect anything? i noticed the car it came off of, it had a blown 02housing gasket since the divider is not there. would it cause turbulance or anything like that?
i search and searched and came up with nothing about havindthe divider take off
Dejon powerhouse used to offer this service with its turbos in order to help with boost creep, they got the idea from PTE. it's there to allow even more exhaust to flow freely past the turbine when the wastegate is actuated
I'm guessing your talking about something like this?
As said above this is the purpose of removing the divider...
As long as your not running a wastegate off the o2 housing there isn't any problem running a housing like this.
yes something like that but mine dont looks as good, let me see if i can upload a pic real quick
oh ok thanks, yeah i was freaked out LOL, i was like wtf..it has a big chunk missing ..im working on the pics right now
here are the pictures
so then i assume its not gonna affect anything?
nope it shouldn't adversly affect anything, until you need to run an external wastegate.
it's a little trick to reduce boost creep that E3 turbos are apparently know for
Cool man, thanks for the info. I doubt ill run this turbo with a external wg
I'm not tracking. How would this be a bad thing if you ran the wastegate off the O2 housing? Am I missing something simple?
Maybe since there is nothing separating the exhaust gasses and the wg gasses , maybr the exhaust gases can open up the wg I dont know..just thinking out loud here
Gasses for 'gates on the manifold aren't separated either. It's the boost source that's supposed to open the 'gate.
I have no idea then on how it could be bad to run a wg on the o2 housing cause I'm interested on that set up so someone chim in
If you do porting like shown above you cannot run a wastegate off the O2 housing. You only can run an internal wastegate. With that wall removed the exhaust gases will just flow out the wastegate hole and straight into the exhaust avoiding the wastegate. It would be like running with no wastegate or with the waste gate always open.
Here are some pictures for your viewing pleasure. When you run a wastegate off the O2 you remove the flapper. So in my pictures it is assuming you use something like the Mild Steel 38mm Recirculated o2 Housing For Eclipse/Talon
I figured out what was going on, even though I don't think your drawings do a great job of explaining it. The issue isn't getting exhaust through the wastegate, it's getting exhaust through the turbine when it can go around the turbine instead. So the issue isn't overboost, it's underboost.
So either way can't run a wg on the o2 with a turbo that has that mod, only thing is to run a wg off of the manifold
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
  • For sale 1g 1g BR upper intercooler pipe. Stainless Steel
    1g upper pipe. Early BR. 2.25 inch Stainless. Bead Rolled ends. BOV flange is gone...
  • For sale Anyone interested in brembo front brakes from a evo x?
    Hey guys I happened to come across evo x brembos that work great for a good price !
    • SheNeverRuns
