Porting question on my .63 ar housing
Geeb
384
50
Apr 6, 2016
Philadelphia, Pennsylvania
I have a pte bb 6165 with a "ported s" .70 ar compressor housing, and a .63 ar turbine housing.... We all know the .63 is going to limit hp numbers, and I've recently bought so many parts to try and make my build get at least close to the 600 hp mark, but I know with this turbine housing, it's going to limit me way down to like the 500ish hp mark if I'm lucky. The turbo is rated at like 670+ but I know thats with the largest housing they offer...
So my question is this, do you think if I port this .63 out a ways, I know I'm not gonna hit .82 numbers but would porting this out at least pick up a few hp? Even if I have to sacrifice with some lag.
Trust me I'd love to just pick up a .82 and be done with it, but porting this turbo will only cost me time and shop consumables... Which id gladly spend compared to more $.
I might just have to accept that my max at this point will be around 500. :notgood: but oh well it is what it is.
Would porting it at least put me somewhere in the middle of a .63 and .82 just so it doesn't choke on not enough flow? Or am I living in la la land.
Thanks guys.
You can't port a housing into the next a/r no more than you can port a 2.0 engine into a 2.4.
If anything, porting too much can slow down velocity and ruin a good-flowing housing. On an internally-gated turbo, pre-wastegate porting can indeed help you some and you always want the path to the gate to be free-flowing and unobstructed, but assuming the transition from the manifold flange to the turbine inlet is smooth there's absolutely nothing you stand to gain without changing to a larger a/r housing and dealing with the lag.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
