housegsx
- 2,455
- 44
- May 28, 2004
Greensburg,
Pennsylvania
I just got back from vacation a few days ago and was able to get this finished up last night night.
First thing I did was replace my proportioning valve. That was nice and easy, it only took me a few minutes because I don't have cruise control or a battery etc in the way. Before I put the new one on I screwed each open line into the air nozzle from my compressor and blew out each line.
New valve
Once the Evo brake lines came in I was already disappointed because they were the wrong color. I tried to fit them anyway, but the Evo lines are just too long with the wrong fittings to work nicely on a DSM.
You can see the bend in the line is kind of tight, it's also slightly twisted, and the line touches the knuckle. No good. I'd like a line with a 90 degree bend on the banjo bolt and a slightly shorter hose.
For now I am just using my SS DSM lines with the addition of a copper washer.
After all the lines were tightened I bled the brakes with ATE Blue. It was nice to see when the fluid went from yellowish to blue and I knew everything was clean and air free.
I bolted the wheels on and it should be ready to go now. The plan is to take it for a drive tonight if the rain stops, making sure everything feels right and bed in the new pads and season the rotors.
Here are a couple pics behind the wheels. 17x8 with tons of clearance.
New valve
. Are those the 40mm offset ones? If they are, I do want to warn you that the fronts probably won't fit without a spacer, unless you're running something different. It LOOKS like it will, but the brakes wouldn't clear on mine without a 3mm spacer.
