95EclipseGST
- 406
- 1
- Mar 1, 2002
Kansas City,
Missouri
My engine was making knocking noises and then finally heard a hard knock as i pulled up the driveway and the engine was dead.SO i pulled the engine completely out,took off everything and dropped the oilpan and bolts inside around crank area.Shined flashlight up to see piston rods etc.They were all there and didnt see anything like a broken rod or anything wrong.No metal shavings in oil pan BUT when i put a socket on the end of the crank and try to turn it with all i got,it is completely frozen up and wont turn either way.All there is left to the engine now is basically crankshaft and pistons.the crank wont budge either way to check for crankwalk either.What could this be? Could the crank bearings have froze on each end? The car had clean oil in it so i dont think the pistons froze or anything.Could piston rings have slipped between the piston wall and the piston itself to cause this? I am pretty new to this stuff but have enough mechanical skills to drop the engine etc.Can someone help me diagnose this please? Under the oil pan,I took out the metal plate and the screen filter thing and then pulled off all 8 or 10 of those long bolts that go up in the engine to secure the crankshaft.What else is holding these in? How do i drop the crank from here? I cant turn the crank to loosen the piston rods away from the crank ,cause most of the bolts are where i would have to turn the crankshaft.Help Please, Thanks. Travis
