theomhd
- 0
- May 13, 2010
Everett,
Washington
I started the process of pulling the engine today.
I have pretty much gutted the passenger side of the engine:
I also pulled the radiator and disconnected the throttle cables.
The radiator has a pretty thick layer of oil along the bottom 1/3 of the fins from the engine leaking oil.
I think next I'll be pulling the power steering pieces, AC, alternator, the vacuum lines and electrical on the drivers side of the bay, and then engine mounts and drive axles last before the engine can be lifted out.
I have never gone this deep into a car before so I'll be the first to admit I'm in way over my head and winging it as usual, but I'm having fun so hopefully all goes well
I'm going to replace the water pump, all the belts, all the vacuum hoses, the lifters, oil pan and oil pan gasket, and valve cover gasket while I have the engine out.
Any suggestions before I dig into it more this afternoon as far as plan of attack and items I should replace/check while I've got it out?
Wish me luck!
Wish me luck!
