92AWDTalonTSI
- 334
- 8
- Jun 2, 2010
Somonauk,
Illinois
Will improper emission removal cause low or high idle. Also after giving up on searching because the servers keep timing out when I search. I was wondering if it is the same to just remove everything connected to the EGR as it is to just remove it and install a blockoff plate.
The emission removal on my neighbor's car is a bit iffy. The "P" vac line splits three times and the boost gauge isn't even hooked up. Weird huh? There are quite a few lines still hooked up under there. Most of them going places I have no clue what they are. The P.O. said he couldn't get the idle to go down. I believe the BISS O-Ring is good still and the timing is correct. But it still idles around 1500.
and I don't have a CAT on mine either, but my car is going to be a weekend track car when done anyway. But like "9!"clipse", says, he passes then go for it.
