2G EGR removal and now start and dies
69_luv
522
9
Nov 3, 2003
Jacksonville, Florida
I removed all of my egr equipment including the charcoal canister, all the hard lines, and everything under the battery tray. I used the egr blank-off plate sold by FFWD.
I used this link:
http://www.dsmtuners.com/forums/art...-speed-shop-vacuum-diagram-removal-1g-2g.html
and:
http://www.dsmtuners.com/forums/art...249879-egr-block-off-plate-install-guide.html
Does anyone have a picture of what the intake manifold/throttle body is supposed to look like? Am I supposed to cap off every nipple? I took a picture of it right now and circled in red all the ports I am in question about. I tried capping all of them, and only some of them and all did the same thing.
Right now the car starts, goes for about 3 seconds and then dies. It will not stay running.
Half my problem is solved. Somehow I had left the plug for the CAS unplugged and as soon as I plugged it in the car runs perfect. :ohdamn:
My question still remains on the throttle body/intake manifold. Am I supposed to pull all the rubber hoses off and put plugs on them, or is there some that have to stay?
The only vacuum lines you'll have left are the BOV, PCV, wastegate, FPR line, boost gauge line, valve cover breather and lastly the brake booster.
    • Sdcryan1
