- Thread starter
- #26
pieceofcloth
Supporting Member
- 576
- 565
- Oct 6, 2019
Houston,
Texas
, im going to get my ecu chipped w dsmlink. I will swap in my new injectors, and install the he351. I may have had some type of fear where I felt the need to break in the engine w the 16g. I'm neck deep and might as well get what is needed to run the he351 which is some type of adapter for external wastegate, then another adapter from 38mm to 44mm. My tial is 44mm and I can not afford the TSmanifold to properly complete this.
. It did not bother me one bit because my love for this machine and will is stronger than my inner bytch. This machine has taught me extreme patience, knowledge of engines, turbos, fuel & so much more. Reading everyone's situations and everything on this forum back and forth has helped me more than i can explain. I have built a specific pride in all of this and can now get an idea on how most of you guys feel.
.Yeah it's pretty incredible. As soon as you install or get most of the way there you then have to redo stuff all the time. I've never been able to get the timing right on the first try even after all these years but it's worth it to do it right.i also Purchased the alternator relocating kit and even in year 2021, no instructions included & their pdf link doesnt work ,so i went off pictures and common sense.
Mannnn, you aint lyingYeah it's pretty incredible. As soon as you install or get most of the way there you then have to redo stuff all the time. I've never been able to get the timing right on the first try even after all these years but it's worth it to do it right.
. Thank you, im going to see how it fits today.I hope that j-pipe fits. A lot of them are really tall and would likely not fit that setup. If it doesn't, you can just buy a 12-18" 2.5" pipe and a 90* couple and use those as your lower pipe setup.
Man im not quite sure yet. The oprv is a spot that i knew was leaking. I was thinking the same about the pan & I do have an extra fel pro laying around in the living roomDid you find the leak? From looking at the pics, it looks like the oil pan to me. My oil pan was leaking and it would get on the timing cover. Guessing the motion of the crank pulley slings it all over. I used a felpro gasket and that fixed my issue.
