Ecuflash help
dsm94
44
Jan 11, 2008
Saint Peters, Missouri
Hey just installed my 660 densos and ive set my wot scaling to 690 and idle ft are set right, now im cruising on the freeway about 15-16min into driving my car goes really rich like 10-11 afr on my aem wideband. If i even give any throttle it goes really rich. Dont know what is going on help please!
Thats wierd that your injectors are scaled above what they are supposed to flow, usually they flow the same or a bit less even. What are you using to log? Have you calibrated your wideband?
You may need to start touching the maf smoothing tables according to ceddy's tuning guide.
Yeah according to ceddymods if your wideband doesnt match up to your ecu afr then you need up your scaling. thats what i did. to 690. but im not sure if my car is going into openloop or closed loop while cruising. maybe thats why im running so rich? or are my fueltrims maxed out and its way out of wack?
Yeah im at work now. I have to setup my wideband aem to evoscan not sure how to do that yet. Then ill post a log
