I want to ecuflash help?
slonkey
225
Apr 9, 2012
ST.Louis, Missouri
Have a 97gst and I want to flash my Ecu but don't want to buy a 500$ program or wire. Please help for cheap alts.
$500 program? Ecuflash is about $200 total (if you have a flashable ecu). You need a 98/99 black plastic case ECU-
~$125
Flash connector from ECU- $5
Tactrix 2.0 flash cable with mitsu flash connector- $189 from Tactrix.com
Evoscan- Evoscan.com- $25
Ecuflash- Free- openecu.org
Done.
Well I was looking for a link or something and everyone is like 400-450$ maybe 500
Edit: couldn't I just get a Ecu from like a junker?
I gave you website links to buy your stuff from in my post, along with pricing for it.
Since you don't already have a flashable ECU, a cheaper alternative to the flashable DSM ECU is to convert to an Evo 8 ECU. You would have to swap a few wiring harness pins at the ECU, or buy a patch harness, but the Tactrix 1.3U cable is cheaper than the 2.0 and will flash an Evo 8 ECU as well as allow for faster datalogging. Also, there is way more support for that ECU over on evolutionm and Tephra doesn't charge for his custom coded features.
So it ends up being:
1.3U cable and EvoScan = $157
Evo 8 ECU = <$150
Download ECUFlash for free
It's a bit pricey and not totally necessary, but I also sprung for the optional patch harness when I did mine.
Evo 8 ECU = <$150
As far as getting the 1.3U, obviously price high, however, I've bought 2 1.3U cables and had the oppurtunity to buy more for less than $30, so that only puts you at about $60 plus the Evo Ecu which is almost cheaper than going with just the 2.0 in general. Not a bad alternative to have many more features and expansions.
Got a link or something?
delta448 said:
Just make sure it's one that has a reflash connector and a limitless serial number, the $20-30 eBay vag-com cables can't be made to work with the newer versions of ECUFlash.
Ok thank
Evo 8 ECU = <$150
I would agree with you except good luck finding an evo8 ecu for that price. And if you do please point me in that direction.
I am also going the ecuflash route on my 95 AWD talon.
I've been meaning to do it for a while; I already got a 98-99 flashable ECU, Evoscan, and a 1.3 Ebay cable to log. I know I need the 2.0 tactrix cable to reflash, and some connectors/ adapters since my car is a 95. but I'm having trouble choosing where to buy the cable.
At Evoscan.com they call it "Tactrix OpenPort 2.0 Universal USB Cable" at 237.00 with full set of mitsu & Subaru reflash connectors (which I don't need). At Tactrix.com they call it "tactrix open port 2.0" and sells for 169.00. Does the cheaper one include the cable itself? It only shows a fancy OBDII connector on the pic. (No cable)
Also the "Reflash connectors" look diff. on both sites, anything diff. other than price?
Is there anything else I need (other than ECUFlash) to get this done?
***To the OP, sorry to hijack your thread, but this might help if you decide to get the 2.0 cable.
Thanks!
I&rsquo;ve been meaning to do it for a while; I already got a 98-99 flashable ECU, Evoscan, and a 1.3 Ebay cable to log. I know I need the 2.0 tactrix cable to reflash, and some connectors/ adapters since my car is a 95. but I&rsquo;m having trouble choosing where to buy the cable.
At Evoscan.com they call it "Tactrix OpenPort 2.0 Universal USB Cable" at 237.00 with full set of mitsu & Subaru reflash connectors (which I don&rsquo;t need). At Tactrix.com they call it "tactrix open port 2.0" and sells for 169.00. Does the cheaper one include the cable itself? It only shows a fancy OBDII connector on the pic. (No cable)
Also the &ldquo;Reflash connectors&rdquo; look diff. on both sites, anything diff. other than price?
Thanks!
That's cool brotha it will help for sure
Is the Tactrix 10.00 or 11.00 dollar reflash connector the same as the the 2.50 one from Evoscan.com? (just re-designed?
Thanks!
  • Wanted 6 bolt NT water pipe
    • chrisman287
