Help! I want to stop venting!!!!
KeithL322
42
Oct 6, 2005
Clarksville, Indiana
ok so, when i bought this car it already had the XS RFL on it, I want to recirculate, ASAP. I'm just going to buy a 1G BOV for now, since the guy didnt have his anymore, moron. anyways where is the best place to find a 1G BOV(i klnow they have one on slowboyracing, but its EXPENSIVE,i just want the stock one,not a blingy one) also, do i need a new BOV flange? or anything, and where can I find a recirculation hose at, or what pieces should buy to make one? THANK YOU FOR ANY HELP GIVEN!!!
I bought mine of Ebay, used for $25 and it came with the flange and pipe, although I latter had a custom pipe made. You can buy then brand new from the dealership for about $115 if you want a new one.
Why don't you just find a decent fabrication shop and have them take off that "horn"(it does unscrew) and make you a new piece to vent back into the intake. Then just look for a flexible type of hose to connect the two. I had it done because i was in the same boat as you.
yeeah i found a thread on it earlier, but now i cant find it ne where? :confused: the guy just unscrewed it and got a threaded metal piece to sitck in it, then ran line to the recirc on the intake, cant find the &*mn post tho
What type of shop would be able to fabricate a threaded metal piece for me? or would i be able to find one at Home Depot or Lowe's?... I thought about doing that, but I don't have a piece that i can fit in the hole to get a good seal made by the horn :( If anyone knows where I can find a Thrreaded piece that will fit that (Anyone happen to know the diamater?), that would be AWESOME, thanks alot guys
